Hahaha no problem Blues, we just went off on a tangent lol!
Wow, I didn't mean to sound so vague in my post to op. I just didn't want to take up 2.5 pages of this thread talking about metallurgy
I understand that there is no distinction/definition of "hard or soft" steel, but in the instance of op's "why is s30v better at holding an edge that a noname/sak steel" I think its safe to say s30v can be called "harder" and will hold an edge longer than said steels (not all). S30V is harder to sharpen than something like sak steel because it is harder and more resilient.
I dont claim to be an expert, but I didnt think op wanted a scientific explanation![]()
S30V holding an edge longer than the other steels has less to do with RC hardness and more to do with Alloy content/Carbide content.... Same with being somewhat harder to sharpen, it's more wear resistant than those other steels due to the Carbide content.
So tell me please, Ankerson, do you have a doctorate or advanced degree in metallurgy?
Well the SAK Steel is in the 55 range and I have personally seen S30V in that same RC range.....
So both steels in the same RC range and S30V will still hold an edge better.....
That why we went off, because it's way too vague to be even close to being remotely accurate.....
I do understand making things easier to understand, but that was/is really vague.....
Vague enough that anyone who knows what they are talking about would go.... HUH? WHAT?
Sometimes we just can't dumb things down THAT far..... And still make since or be accurate....
That's like telling someone man my car is fast, I put gas in it and it goes.......... HUH?.......
You make some good points, but I was under the impression that vanadium carbides are strong/harder than a sak steel which presumably has no added vanadium (thus making one harder than the other). Like you said, regardless of rc, the s30v is made to hold an edge better due to more than one factor.
Think of it like concrete with rocks in it, the rocks are harder than the concrete.
There is soft and hard in the non-technical world of the Average Joe
They know nothing about metals and steels,
Except the blade is soft when it is easy to sharpen and gets blunt fast
And a blade is hard when it is difficult to sharpen and stays sharp
We might be intellgent and understand what he means is infact a composite of complex issues
And transalate this in to his view
But no amount of technical insistance here will change a common man's simple and accurate perception
EXACTLY......
And we are back to the original question....
WTF is a hard or soft steel.....?
And were in the hell are they getting that terminology from?
You seem to understand metallurgy better than you understand English. The original question was not "wtf is a hard steel."
and while it may not be the only factor in edge retention, hardness is a factor, so to talk as though it isn't is rather misleading, don't you think?
There are a lot of factors that are involved in edge retention.
- Alloy content/Carbide percentage
- Edge geometry
- Blade Geometry
- Edge finish
- RC Hardness/Compression strength of the steel
Compression strength is directly related to RC hardness and since edge dull mostly due to blunting, rolling etc so the higher the RC is the longer the edge will go before it starts to deform so the edge will stay sharper longer compared to the the same steel at a lower RC hardness.
Wear resistance is important and is directly related to alloy content/Carbide content so that will have an effect mostly on more abrasive materials being cut.
Blade and Edge geometry are important because the thinner the blade is and the lower the edge angles are the easier it will move through the media being cut. Now if we get too thin for the use at hand the reverse will happen and the edge will dull too fast so a balance has to be met. Too high RC hardness and the edge will chip out too early and dull too fast.
Guess you didn't read the whole thread.....
Like the parts when I pointed out they aren't referencing actual RC hardness when they say hard and soft steels....
Or this post that I made.....
I did in fact read the whole post, including the original question. Did you?
The original question was "how long should a razor edge last?"
I suppose my best answer would be, it depends on the blade, as well as how you use it.
Not real technical, perhaps not real satisfying. I'm sorry, but that is the best answer I can give to the original question.
So how is it you did not know what the original question was?Yeah, after reading the 1st 5 posts I made #6......
The answer really isn't THAT simple, and I wanted to find out what people thought a hard and or soft steel is as I have seen the terms used lately in different places as they were here.....
And as to my admittedly simple answer,
Does it not depend both on the blade in question, and also how it is used?
Along with a lot of other factors that can effect the outcome....
Nothing is that simple...![]()
The question was simple, so i figure the answer should be too. I think you are trying to substitute some other related questions for the original.
