Yes of course. I guess I’m tiredRH = Rockwell Hardness.............I think![]()
I also think that's what he meant. Isn't Rockwell Hardness normally abbreviated as Rc, for Rockwell C scale?RH = Rockwell Hardness.............I think![]()
A roll is around $300 and good for at least 300 blades minimum so about a buck an envelope. When you count the price of steel, cryo, scales, epoxy, belts, and time a buck for foil is really not a huge factor in the outcome of profit. I’m not saying $300 is cheep but it will last a min individual a very long time.Yes RH was shortened to mean Rockwell Hardness. I just assumed knife makers would understand RH. Like I said I've got a bunch of AEB-L to heat treat tomorrow. I'm going to do a test. One per SS foil. Two per foil pack. And 3 per pack. I will engrave the 3 pack as 1,2 and 3 to see if there's difference. Like I said I've done it before and they all turned out great. But I've had ONE failure but I'm thinking it was because of lag time till I did the cold treatment. Maybe as HSC suggested maybe a longer soak time. Thanks for all the input! I can always count on honest input from this forum. I've learned a ton from this forum with all the experienced posters who graciously post their knowledge. Thanks.
But I beg to differ SS foil wrap is expensive. Maybe you get a discount because of the volume you buy. Good for you. But to a hobby maker foil isn't cheap and it has to be considered in the price for sale or give away.
Thanks for reporting the test results, that's pretty encouraging.Well I did some testing during my HT yesterday. I stacked 3 identical profiled unground blades of .60 AEB-L and engraved them 1,2 and 3 on the handles. With 2 being the center blade. I added 2 minutes to my normal HT. Plated quenched then cold treatment with dry ice. The center blade came out .5 lower in Rockwell hardness. I also did some small chef knives .90 identical profile unground AEB-L. I put two to a foil pack with remaining knives one to a pack. Same HT with only the normal minuet differences in Rockwell hardness with single wrapped versus double wrapped.
I am happy with the results but what I'm most happy about is that with my homemade carbide hammer I was able to straighten the few slightly warped blades with it! My homemade carbide hammer was made from the cheapest small claw hammer with a wooden handle I could buy. I used a angle grinder to grind off the claws and rounded them over. I cut the wooden handle off at base of hammer head. A little torch time and wood came out and I saved the wedges. I annealed the hammer head and then drilled a 1/4" hole in the flat of the hammer. I cut a carbide 1/4" Boush carbide drill bit to the proper length with my dremel and also rounded the end of the carbide bit with it. I then JB welded it in the hammer. I was worried since the area of the bit JB welded in hammer head was fluted it would not glue up and last. I used the belt sander to reshaped wooden handle to fit back in hammer head. So far it's held up perfectly and worked awesome!
I don't stack my blades because of the cost of the foil.... I do it because it's more time and cost effective to get 2, 3 or even 6 blades per furnace cycle.A roll is around $300 and good for at least 300 blades minimum so about a buck an envelope. When you count the price of steel, cryo, scales, epoxy, belts, and time a buck for foil is really not a huge factor in the outcome of profit. I’m not saying $300 is cheep but it will last a min individual a very long time.
Sounds like you need a bigger oven and more quench plate set ups lolI don't stack my blades because of the cost of the foil.... I do it because it's more time and cost effective to get 2, 3 or even 6 blades per furnace cycle.
I guess I should have been more specific once again. I don't have a true carbide bit. I used a 1/4" masonry hammer drill bit that has a carbide tip. Unlike others I've never had any luck using a carbide masonry drill bit to drill hardened metal. It was way easier to anneal the hammer head for me.
I guess I don’t understand how that would help me so please explain...Sounds like you need a bigger oven and more quench plate set ups lol![]()
He means you could wrap each blade individually and still put multiple blades in one oven during one heat treat. Wrapping each one individually wouldn’t decrease the number you could do at once.I guess I don’t understand how that would help me so please explain...
if I have a given time, Let’s say one hour for a furnace cycle, quench and into liquid nitrogen, why wouldn’t I try to get as many blades as I could during that time? If there are no detrimental effects.
Yeah I figured. Just didn’t want to assume. Yeah I’ll pass on that. I’m good stacking the blades or putting them side by side. I see no benefit to having to pull out multiple packets and put them on a quench plate.He means you could wrap each blade individually and still put multiple blades in one oven during one heat treat. Wrapping each one individually wouldn’t decrease the number you could do at once.
If the results are the same I can't imagine not doing it.
