- Sep 10, 2004
Lots of ways to do this successfully. I have put as many as 10ea per pack. Now I keep it simple and only put 1ea per pack. Stay safe out there.
www.snodyknives.com
www.snodyknives.com
But the results are not always the same. this is from post 10-
I just finished profiled only 9" chef blades by stacking 3 of them using Hoss's HT'ing recommendation of soaking at 1725°F for 20 minutes, then 10 minute soak at 1925°F and plate quenching, then overnight in LN. After tempering at 350F the blades are 63 Rc, 60 Rc, and 59 Rc.
But my results show the results are the same. IDK. I'm not a professional knife maker period. But I do run two successful sole proprietor businesses. IF i can save time or money in either you can bet your ass I'm going to do that if the results are the same.
It tells you how hard it is, it doesn’t tell you how you got there. It doesn’t measure toughness, grain size, carbide volume, etc. Aus temperature and tempering temperature can vary and you can still have the same hardness. There is a sweet spot for any steel alloy.Hoss, can you expand on your statement. What else other than hardness defines a successful heat treatment? Please don’t take this question as combative. I am just getting into heat treating and it’s a genuine question for me to learn.
Truth!It tells you how hard it is, it doesn’t tell you how you got there. It doesn’t measure toughness, grain size, carbide volume, etc. Aus temperature and tempering temperature can vary and you can still have the same hardness. There is a sweet spot for any steel alloy.
Good heat treating takes practice and lots of testing, not just a furnace and a rockwell tester.
Hoss
So as a new guy learning heat treating, what am I to glean from this? I can test knives ive heat treated by breaking them and measuring the force it takes to break them. Then, obviously I can analyze the grain size. But it seems like most of that work has already been done by guys like @Larrin. So I can use his data as a staring point and run tests on my knives to make sure my equipment is putting me where I want to be?It tells you how hard it is, it doesn’t tell you how you got there. It doesn’t measure toughness, grain size, carbide volume, etc. Aus temperature and tempering temperature can vary and you can still have the same hardness. There is a sweet spot for any steel alloy.
Hoss
"The Peoples" knife maker is back.Truth!
Larrin is my oldest son. I’ve seen, and helped with all of his research. There have been lots of false claims over the years, there have been even more poorly heat treated knives.So as a new guy learning heat treating, what am I to glean from this? I can test knives ive heat treated by breaking them and measuring the force it takes to break them. Then, obviously I can analyze the grain size. But it seems like most of that work has already been done by guys like @Larrin. So I can use his data as a staring point and run tests on my knives to make sure my equipment is putting me where I want to be?
Wad up Snody.
Never met ya but loved all the videos back in the early 2010s
Thanks man. Hey if your ever in Southern Colorado come visit and hang out for a while. Respect."The Peoples" knife maker is back.
Wad up Snody.
Hoss
