Alright I have to know,
Why do high vanadium steels work better with a coarse finish?
Whats the mechanism involved?
Because vanadium carbides are very hard, and the finer grit you go the longer it takes to actually cut through the carbides to achieve that grit finish uniformly along the full length of the edge. This is assuming doing it by hand because anything with power sharpening equipment can be done much, much more quickly. To achieve a "uniform" (obviously not perfect) edge you have to cut through the carbides and not tear them out. Even with diamonds this can take some time when done by hand depending on the amount of material that needs to be removed. However, if the sharpening media is too coarse you can end up with carbide tear out because the carbides aren't abraded they're simply removed from the steel matrix. It's far easier to abrade the steel matrix than to wear down the vanadium carbides.
