Yvsa,
that's true, Galileo first noticed that and reported it in his law of falling bodies. Then Newton built upon Galileo's research and came up with what we call gravity. And at sea level on the planet Earth all objects fall at approximately 32 feet per second squared.
Well, that's how it works in a vacum atleast. Once you introduce an atmosphere you introduce drag, and once you introduce drag you introduce a terminal velocity. For a human being in freefall you hit your terminal velocity around 300 miles per hour, assuming one standard atmosphere. In project Excelsior, back in 1959 a guy jumped out of a balloon at over 100,000 feet, and broke the sound barrier in freefall, he still holds the record for being the fastest moving human being without the aid of a vehicle.
With a piece of silk the drag is very high and the mass is very low. So it has a very low terminal velocity, so it just won't move that fast without the aid of an outside force. That's also why soaking it in water helps. It adds to the mass of the item, which adds to its inertia, which means that it gives more resistance to being pushed out of the way with the blade, so it is more likely to be cut. Same thing with a water bottle. You have a free hanging emty bottle, and you're not going to cut it. You fill it up with water, and you're going to split it like a ripe watermellon.
Have I, in the past few days, displayed my true nature as a science, and computer geek????
I really need to get a girlfriend.
