Thank you my brothers. I forgot to important information. I recommend you to make a hardening of your straightening hammer, and make a aneeling for fifteen minutes. Example: If you aneeling O1 steel for 1 hour at 480°F, make only the same temperature for 15 minutes!
Proceed the straightening blade with is hardening an aneeling! Regards!
So the blade should be still be hot when you attempt this after the anneal/temper? Or it has cooled down totally?
Dick, I really do not how to say. The hardening on oil in Brazil we called "têmpera". The heat treatment after, to reduce excessive hardeness, at one or 2 hours in the oven we called "revenimento". That is called "aneeling"? Do I correct? Please, teach me! Thanks!
têmpera = hardening
revenimento = tempering
annealing is when you heat the blade to critical (or just below critical) temperature like 800C and let it cool very slowly so that it is very soft and easy to grind, drill, or machine
The blade is cold brother! After hardening!
Success, or at least a good start.
Have a forged 1084 kitchen knife, 8-9" blade, cold and annealed, soft state prior to HT.
Blade wavey, (couple of small curves) not bad, but couldn't get a good centerline mark. Got out my small ball peen, pulled a chair up to my anvil and went to tapping. Tried to mimic the video here. Very pleased with the results. Will HT and temper soon, we shall see.
Big thanks from South Louisiana. Dozier
