Shaving wood like pine or cedar shouldn't dull a knife too quickly. I would have doubts about any blade that couldn't make a fuzz stick without significantly dulling the edge. Impact and trying to baton through knots might mess up a thin edge.
IMHO, convex edges rule for heavy use.
As to the firesteel, if I had to use my "good" knife, I would scrape using the very base of the blade.
Other options:
-Square the spine edge in one area for scraping. Moras are perfect for this.
-On an SAK, sharpen/square the screwdriver tip for firesteel striking, or notch the side of the screwdriver with a Dremel to fit your firesteel diameter. Check out the specialized firesteel scraper notch built into the Light My Fire SL3 knife:
-Of course, you could use the factory scraper or make one from a hacksaw blade and avoid the issue.
-Use a
pico wedgie prybar from County Comm
-Use a p-38 can opener
-Use a Craftsman 4-way pocket screwdriver-- this is an item that is great for a all-round EDC and survival pocket tool and should be mentioned in this forum.
-I add SAK Classics to my survival necklace/lanyards to use for firesteel scraping. I should square the edge of the nail file and save the blade.
This is all aimed at survival scenarios. If you use your firesteel a lot, I would have a dedicated scraper.
