An important thing to consider with all this is that we need to look for steels that are suitable, which may vary depending on our concept, type of blade we are making, shop set up (equipment), skill and experience levels etc., and whether or not we plan to forge or use stock reduction. However, there are some types that we can weed out from the get go, (with the exceptions of possible special applications), stainless steels (with the exception of high carbon stainless for stock reduction), low carbon steels, cast iron, and wrought iron. For sure we can weed out galvanized steels.
Just for starters:
Galvanized steels can be recognized by the bright rough or crystalline silvery looking metallic coating.
Stainless steels, as has been mentioned, are sometimes non-magnetic or barely magnetic, have a smooth bright silvery look. High carbon stainless steels are air hardening.
Low carbon steels are soft and wont harden significantly.
Cast iron often has evidence of a sand mold on the surface, is brittle, melts at a low temperature, the fractured surface looks dark grey and has a course grain structure. Cast iron is not hot workable.
Wrought iron is soft, wont harden significantly, and has a bright fibrous look on the fractured surface. Etching will also show a fibrous structure.
Of the steels that may be suitable, we should be able to at least narrow them down with some simple testing into several basic categories based on their chemistries.... #1. Medium or high carbon, #2. Quenching medium, air, oil or water (shallow or deep hardening,... simple or alloy). #3. Stainless or non-stainless. Once we know the general type of steel, then we can look at the manufacturer specs for other steels in that category and start to narrow things down. For example, "high carbon non-stainless shallow hardening".
Simple deduction... Mystery steel detectives!
