- Aug 13, 2002
Great timing. I am in the process of making one with AEB-L and the HT did not come out as good as I'd like. Gotta try the process listed here. Thanks.
Well, from those graphs it does look like Sandvik is saying 15% and not a typo. Also, it looks like quenching from 2050ºF, then into dry ice slurry gives most hardness and less RA at 15%. I was thinking a lower number for RA was the norm for properly HT'd blades? I sure wish AEB-L gave as much HT'ing info as Sandvik does for their steels.
Bluntcut: are those "as quenched" Rc numbers in the top graph give about 61 Rc as max hardness (<2 000ºF) for 12C27 even with dry ice?
Ricky, your "600", isn't that 600ºC? Which is 1112ºF.
Remember folks - taking HT info from one manuf and using for a different manuf is not the same. While both AEB-L and Sandvik are both Swedish manuf - they are still not "necessarily" the same HT requirement. In the real world, they should be VERY close.
Ken H>
@ricky_arthur how can I get in touch with you?
Hoss
Ken H>
Patrice Lemée;15569247 said:Thanks a bunch Lo/Rez. Now only need to buy Dry Ice. Welding/gaz place will have some I think with a minimum of 25 lbs buy (42$). Guess I need to do more than one blade to optimize cost.
Not sure how the do it up there, but here in Florida, you can find it in your local grocery store at times.
