For the best finish you should use a ball and tilt the head. Use good sharp carbide for your finish pass. This will save you quite a bit of stoning.
Does carbide apply even to less rigid machines like an old and worn BP ?
This mill of mine is pretty rigid, at least with the table clamped on the apron... the spindle bearings are good.
Carbide will also let you have much higher spindle speeds for your finish cut and also let you get away with cutting dry. You might also want to play with a shallower depth for your finishing cut, just remember that if you are cutting at an angle your actual down magnitude is less that what you dial in.
-Sandow
I wasn't disparaging your mill....Not when he's raising the table, Z up is up.
