- Apr 12, 2009
Since I don't want to buy a lot of wood at once, I assume I can also mount the leather on the MDF? Will MDF swell if any bit of water touches it?
Yes, you can mount the leather on the MDF if you want to. Pretty much any flat, rigid surface can be used with the leather. With regard to moisture, just be careful to immediately wipe off any water that might come into contact with the MDF. If it stays in contact too long, it'll soak into the MDF, causing it to swell. The bad thing about it is that the swollen area won't shrink back completely after it drys. A lot of countertops in kitchens & bathrooms are made with an MDF core (underneath the laminate), or something very similar. If you've ever seen one of these countertops that wasn't properly sealed, they will swell at the seam areas where moisture gets in. Once that happens, they'll stay that way forever.
