- Jun 1, 2024
OK It won't dry too fast on me if I use activator? I just have to be quick after I spray the activator on then glue them together quickly before it dries?
OK thanks I will hand sand the gloss of with rough 80 grit for a good bondIf you use G10 be sure to remove ALL the glossy surface from it or it won’t bond good and might pop off.
I believe he's talking about the outline, don't try to cut the backing piece to match the tusk exactly before gluing them together. Make the liner bigger so you don't have to spend time tying to get them to match exactly.What exactly do you mean use a bigger piece of g10 than the mammoth? Thicker than the mammoth?
Makes total sense great ideaI believe he's talking about the outline, don't try to cut the backing piece to match the tusk exactly before gluing them together. Make the liner bigger so you don't have to spend time tying to get them to match exactly.
Can't dip in water? Wow didn't know that... Even if stabilized & cast? How come? Wouldn't that make for a knife handle on a blade that could never be exposed to water only?Ugh... Mammoth. I've purchased a fair amount of both cast and stabilized mammoth from several vendors. I've also done a good deal of experimenting of my own. The biggest thing is that it absolutely hates heat. If you overheat it in the slightest while grinding, it's going to become very crumbly and fall apart on you. It doesn't take much heat for this to happen either. If it feels more than slightly warm to the touch while grinding, you got it too hot. You also can't dip it in water, or used compressed air to cool it. You've gotta go really slow, and let it air cool any time it warms up a bit.
You also need to be pretty careful when using a backer. I've had 1/8" slabs of cast mammoth ivory bend like a banana after gluing them to 1/8" G10. The exothermic reaction from glue can be pretty intense. You can prevent this by gluing the liner to the knife first.
I recommend using silicon carbide belts in particular when grinding mammoth. Silicon carbide belts are highly friable and break down/expose new abrasive without too much pressure. Aluminum oxide heats up too much, and ceramic requires too much pressure imo.
These days I typically recommend using mammoth ivory in it's natural form, but crosscut tusk can make that difficult. For crosscut, I recommend stabilizing AND casting the material. It's a pain in the butt, but it's the only way I've really found to get much durability out of crosscut mammoth.
First the material is cast in it's larger form to help hold it together. Then it's cut into slabs .2" - .3" thick and sent to K&G for stabilizing. They use a thinner resin for mammoth ivory than the stuff they use for wood. After stabilizing, the material will have shrunk a bit, and there may be some separation of the dentin. This is when you cast it again (I like to use black dyed resin). The durability at this point will be highly dependent on the resin you choose to use for final casting.
It's a hassle, but it seems to make for fairly durable cross cut mammoth tusk.
Ahhh so if I grind on a water cooled belt that's soaking wet it shouldn't be an issue?That's just while grinding. Cycling the material from hot to cold quickly causes the material to become super brittle.
Once it's ground and finished, it should handle water fairly well. Similar to horn. It will have some expanding and contraction depending on the environment/humidity, but it shouldn't be too bad.
