- Oct 20, 2004
Thanks, Ankerson.
As I said, I'm not for the most part a folder person (mostly fixed blades), so I haven't kept up with the latest advancements. I'd heard of the Tri-Ad locks, but without a frame of reference such as comparing them to a known standard such as a lock-back I have no way of knowing just how much stronger they might be.
I have used a few Buck lock-backs, but I've never had one fail, perhaps because I've never stressed one to that degree.
The reason that I asked is because I designed a folder for a company, and used a lock-back in the design. I figured that their excellent head engineer would have me change it if it were a real problem. I used it because it's an old, proven, easy to produce system. I'm sure they can't license the Tri-Ad system, since it seems to be all locked up (yes, it was a pun), but I was wondering just how much we were giving up in strength and reliability.
Is there any way to quantify just how much stronger a system like the Tri-Ad is than the lock-back? Twice as strong? Ten times as strong?
Curious.
I think that is a hard question to answer. The Triad is basically a modified back lock that adds a stop pin that forces are transfered to instead of the back lock components. It depends on how beefy everything is made in the folder. A Spyderco Manix, a very beefy lock back, might hold half as much weight before failure as the American lawman which is one of the lighter duty Triad lock knives. But one of the big over built Triad folders might be 10, maybe even 20, times as strong as your run of the mill Buck 110. I am basing this on how much weight can probably be hung on the blade before failure. In actual use it would be a little more difficult to put a number on it since there isn't a good way to measure anything for comparison.
