Just my two cents in here on the 3V issue. I've been working with a couple of pieces here, and just did some testing today on the first finished blade I made from it. No, not torture tested, per se, since its a customer's blade, but he wanted me to get some idea of the performance of the steel before making a finished knife out of it for him.
The piece I was testing was a 13" blade camp knife made out of .175" thick stock. At the widest the blade was 1 1/2" and it was flat ground to within 1/4" of the spine at the narrowest spot near the hilt, and full flat ground at the front and tapered. Edge thickness was about .07" half way up the blade before a convex final bevel was cut on it, with the bevel being finer and more tapered also at the tip. With the high grind and taper the heft and balance was more like a short machete or a parang than a heavy duty camp knife....slightly blade heavy, and with a fairly thin profile.
The 'test' medium was green and blown down dry alder trees, from 1" diameter up to 4" or a bit more. Over a half hour or so I progressed from clipping small limbs and trees, to cutting a half a dozen sections from one 4" trunk, including chopping through several seasoned knots in the wood.
At the end of that time the blade would still slice free hanging newspaper and showed now signs of chipping, burrs, dullness or any kind of bending. During a previous impromptu 'test', I dropped the blade point first on an old sheet tile floor from about four feet, digging a divot in the flooring, but otherwise not harming the tip in the least.
Again, this was not a scientific test, but the 3V performed at least as well as 5160 in the toughness it showed during chopping, and did hold and edge better than the 5160 test blade I have here. As Ed observed, once it is heat treated, is takes a lot of effort to flex 3V at Rc 60, and that stiffness showed in chopping too. It did not vibrate and bounce like a more spring tempered blade. Otherwise, it grinds fairly easy, and after heat treating cleans up easier than D-2 or ATS-34. That I found surprising, since it did take a lot longer to work up an edge on it than a similar thickness 5160 blade at RC 57.
madpoet
mel sorg
madpoet custom knives
http://www.angelfire.com/mn/madpoet
melsorg@wcta.net
