Ankerson
Knife and Computer Geek
- Nov 2, 2002
thank you Jim, really appreciate the time and effort you put in
regards
Harbeer
No problem.
Very nice performance, excellent really. :thumbup:
regards
Harbeer
Well 460 cuts on 5/8" manila rope and still sliced phone book paper is excellent. :thumbup:
Wow, great stuff Jim :thumbup:
Appreciate the kind words and it's very satisfying as a new Bladesmith maker to know that I can put out a nice quality edge. In the back of my mind I'm thinking how would the knife have performed if I had thinned out the edge to less than .020....?
Do not worry , this is more test of the knives and geometry ...not the steel . If you thinned out edge to less then 0.20 probably will double cuts , more thiner , more cuts ...he measure needed force to cut ...................simple :thumbup:
I realize it would be a huge amount of work, but it would be interesting to test a few knives at multiple edge thicknesses. Maybe four or five different edge profiles on the same blade would show either a curve or a linear relationship to how edge geometry affects cutting force over the number of cuts.
It would be interesting to see if the curves would be the same for all steels, or whether they'd be quite a bit different.
I am taking donations..... Money wise....
$10,000 per person until I have enough to get started... Then have to have the knives made..... All customs obviously with optimized HT for each steel and geometry and a number of each one, 5 blades per variation .....
Would be extremely expensive, and the R&D involved.... Would take years....
Then I would have to publish the findings..... (Would never happen until the donations came in)
Figure around $100,000 would be enough to get stared and cover some of it.
Around $500,000 and like 5 years min to cover it all taking into count all of the expenses etc, would have to use both CATRA and rope testing.
Nothing is cheap or easy......
Not holding my breath waiting on the checks to start coming in. LOL
What if you started with a zero-edge, full flat grind knife. Maybe Josh or Chris could do one. Then do a light sharpening, maybe like a micro-bevel to get to a 0.01 wide edge. Test it at that geometry. Then resharpen to draw the edge back up into the slightly thicker part of the blade, maybe to 0.015 inches. Repeat at 0.020, 0.025 and 0.030.
That would be five tests of the same blade, same heat treat, just at different edge widths.
I could donate a FFG knife to be ground down to a zero edge. The regrind would cost maybe $100.
We pay you $500 for the five tests. So we're into it for $600. I'd guess we could take up a collection and reach that number. Auction off the knife at the end to reduce costs even further.
Wouldn't work, not valid.....
Not for this type of thing anyway... Would be too involved to take any sort of shortcuts.
That's if any sort of real accuracy would be wanted.
Would have to be something like Spyderco's Mule Team project with the knives ground to different thickness behind the edge, 5 of each thickness per steel and then tested.
That would be 30 blades min at say $150 each depending on the steel and maker just to get started, that's over $4,000 just for the blades alone in one steel.
Would have to buy a sheet of steel and have the pattern water jetted and delivered to the maker for HT, grinding etc.
All the blades would have to be the same hardness + or - 1/2 Point and tolerances would have to be held to + or - .001".
Things can get expensive very fast up into the $100,000's.
That's the reason why manufactures are the ones doing this sort of testing, this stuff costs real money.
Why do you think that would be a shortcut and not valid? The heat treat would be the same. The blade geometry would be the same, except for the shoulder width of the edge. Sharpening would naturally widen the edge shoulders without changing the heat treat. It should be better than trying to use different blades where there is a natural variation in hardness, say 60-62 Rc.
Ah, that's not exactly how it works.....
Can't keep grinding the same blade over and over, it would be seriously damaged, compromised.
You don't keep regrinding the blade. Just one blade regrind to zero-edge.
Sharpening doesn't change the behind the edge geometry accurate enough for testing, the blades have to be ground, flat ground to the various thickness.
Sharpening does change the width of the edge shoulders. It makes them wider. Just resharpen and measure the new width of the edge shoulders.
Micro bevels are not valid, will change the results of the testing so that would be an added variable that would have to be added.
It's not really a micro-bevel, but it would be a very thin edge bevel on the first sharpening, just like any other knife edge.
The edges have to be true and consistent as does the beginning sharpness level.
Just sharpen the edge as you normally do to the same sharpness level.
That's unless you want to factor in different geometries and 5 more per geometry etc.....
Over 50 blades per steel now.
There are no shortcuts if the results need to be conclusive and or valid to stand any sort of peer review.
No one is looking for a published, peer-reviewed paper, just a good way to see how the width of the edge shoulders changes the cutting performance.
The more variables you enter the more money and or blades would be needed along with other expenses.
At present, we know that narrower edge shoulders improve cutting performance, but we don't have a good sense of how that relationship plays out. We don't have to do every steel, just one to see if we can at least loosely define how cutting performance changes with edge width.
Assuming that all other variables are accounted for & precisely controlled. And consistence 15dps sharpened.
Up to 6/8" bevel face length involves. Beside cutting bevel shoulder thickness, slope from this shoulder up to 6/8" from apex need to be consistence & same thickness + length for diff BET. using a blade only 0.04-0.05" thick with 4dps sabre grind, we possibly can ignore the 2nd criteria IFF 0.005" is 50+% better than 0.018"BET. Do this for 62rc M390 & 1084.
So even this can be done cheaply (~$6K: $1K knives/grinds + $5K worth of Jim pain & rope), my hunch - ROI will be quite low!
edit: More interesting -> Hitachi white#2 is a high carbon (~1.15%C) low alloy steel, sure cementites are plentiful but these are wimp when compare to not too hard CrC (forget about harder carbides). Jim - your thoughts?
