Water quench pulls the edge apart, oil quench pulls the spine apart. In my experience anyway.
Yes, the stress from whe water quench initiated the crack, then the oil propagated it. If only oil, probably wouldn’t have happened that way, or not at all. You have to think where the steel is going square, trapezoidal, then square again. It doesn’t happen evenly.Well, I was in the water briefly, felt/heard nothing, and in the oil felt and heard that distinct tink. This was the only crack.
So i gave it a shot. Thought it was a success until i gave the blade a clean! I quenched in the brine 3 seconds followed by quenching in the oil until the blade cooled down completely. Maybe i should try quenching in the brine for 1-2 seconds next time? Both the brine and oil were at room temp.
Walter Sorrels does it all the time. I've done it a few times without problem
Doable ...............but only one knife at timeYep, have wondered about the same thing myself.
But the blade receiving the oil first would seem counterintuitive I would think? Why have the slow quench go before the fast one? Shouldn’t it be the other way around? So the surface of the steel receives faster cooling followed by the internal part cooling slower?
i have thought of that same thing steve, if it goes through the oil before the water, it will not receive as much as a shock from just doing water. curious what others think.
I believe that this would be used for steels that crack in water. So the oil would reduce the 'impact' of water for steels like 1075. I think this would be a good method for a hamon because it would cool quickly but avoid the cracking. If I were to use an oil then water method I would do it for a better hamon activity and would pretty much go directly from the oil into the water; not even a seconds time.It is pointless starting into oil and then switching into water.
Shallow hardening steels have the problem they need to be cooled under 900 °F (pass the nose) in very short time, something within 1 second frame.
That is the critical step; after this the only requirement it is that the cooling has to be continuous until Mf. By continuous i don't mean constant rate, but just straight way down without reheating. The time frame of this continuous cooling doesn't call for shear speed, and any excess it's undue stress where eveness it is the only requirement.
It is the first stage where most oils fall short; it is the second stage where water is overlay excess.
By the way, the need for the second stage into oil (for hypereutectoids) is just because the red heat in the clayied spine needs to be removed before it bleeds into the martensite edge enough to overtemper it, otherwise the continuous cooling could be also air cooling.
Do you mean for heating parks 50?Also has anyone heated their oil (being careful of flashpoint) to make the viscosity more like water?
