not exactly true, kukhris (and HI swords) are heated hot enough to enable the edge to be hardened where they pour the teapot onto it, the residual heat from the unquenched area tempers the hardened bit somewhat, the resultant being a hardened and somewhat tempered edge gradually getting softer back to the unquenched spine. it's quite an art to get that balance, sometimes they get it wrong and either over or under harden the sweet spot or blade tip...also why some people find that the blades get harder & keep an edge longer after you sharpen then a few times, as you break thru the skin of slightly softer steel & reach the harder stuff. all a bit closer to how the japanese coat the area to remain tough with clay, the area to harden is less coated or uncovered, the whole thing heated then quenched, the bits that were coated cool slower & remain softer but tougher. western practice is to heat the whole blank, cool the whole blank to harden the whole thing, then go back at a lesser temperature to temper the hardness to a less brittle structure. more science, less art.
even wilkinson gets it wrong, the brits in india in the 19th c. would still get bent or broken swords after combat even tho they were proofed. if you hit something in the wrong place along a sword you can overstress it - a sword has a sweet spot just like a baseball bat, hit a ball in the wrong spot on a bat & you'll feel the sting of the discordant forces, same on a sword. you should be cutting with at most the forward 1/3 of the blade, most combat cuts were done with the 1st 6 inches or so. if you start the cut further back you can either not cut at all or damage the sword. at least a bent sword can be straightened in the field & reused to save your life if needed, a broken one is more trouble to fix.....
the damaged sword appears to still be in the bent scabbard, which of course kinked and entraps the blade. what damage was done to the blade will be revealed when the scabbard is removed, if it within it's recovery angle the blade may straighten & be OK, if not it may retain the bend, any hardened edge may be cracked up into the more tempered area of the blade, or it may be in two pieces, all speculation till the day of unsheathing.....
to me, it looks like the whole thing fell or was thrown off the truck and got run over, either by the truck or a forklift with one end propped off the ground by something (probably somebody else's now defunct package) to make it worse. my dad was a postal inspector, so i am never surprised at what postal and delivery people do routinely, especially when things are slack & they get bored.
