- May 29, 2020
4" blade - Spyderco Endura
3" blade - Spyderco Delica
Hole in the blade is terrible idea for weak, unsensitive fingers !!!
Period
Thanks to all for the advice. I was wondering about the Manix 2XL as well. With the Manix could I just use my thumb to one handed open it? I can't use my middle finger to flick it open and don't do well with the Spydie drop open or twist tie method.
I think trying to get a doctor s note to carry an illegal knife may not be a good idea. But I m not a policeman or lawyer.What about an automatic? Even if illegal, you can probably get a doctors note.
Yeah, it’s kinda YMMV with the Tri-Ad lock. My Voyager XL disengages easily, AK-47 was hard as a MF on day one.Cold Steel AD10 is 3.5" blade , but has a big folder feel due to broad blade and generous handle .
Smoothest , easiest opening and closing of any Tri-ad lock . I can do left handed , which is my "weak side" and has moderate arthritis of the thumb .
4Max Scout is larger and reported to be pretty smooth , but I can't testify because I don't have one yet .
Many wave type openers might work for you .
Or use the gravity , shake down method to open inertially . Most of the larger , longer , heavier blades actually open easier this way than smaller ones .
If thumbholes are an option, and you want a good slicer, Spyderco has many options around 4“. The Manix XL might not be the easiest to close though. How about the Amalgam ? Typically $189, though, but a great knife, and gentle on the eyes of other people ... easy to open via hole or flipper.
Do you know of any states that allow you to carry an automatic knife if you are disabled?Having a disability changes things. Some states have provisions to help those with physical limitations.
I was not recommending breaking any laws.
A small fixed blade may be a better option anyway.
My hands are getting stiffer by the year. I find the Spydie Para 2 a big knife, that is easy for my hands to open.
So the Amalgam should be perfect, if you want a larger knife than the PM2 (see the OP): same lock, same hole as the PM2, and in addition a flipper, if the hole doesn't work.
Great. Link me to where it says that someone can carry an automatic knife legally if they have a disability.Pretty sure every state has some variation there of!! Even New York has a disability clause!!!
