Titanium actually deforms before it wears and "grips" the contact point on lock face in a way that steel wont.
I personally see this as an advantage in a lock on top of the lack of weight and corrosian.
I've read this as well. The added grip would result in greater lock security.
Unfortunately, it's not. I have a feeling the titanium liner cant hold up to a steel blade.
Makes you wonder why they chose titanium instead of stainless.
do what? so are ya saying he should go to steel liners? he did for a while and everyone griped and said they preffered the ti.
FWIW ti liners have been standing up to steel blades ever since the liner lock was invented by makers as diverse as pat crawford, bob lum, emerson, really just about anyone ya care to name who makes liner lock knives.
Grip is one thing, but having to pry the lock back with a butter knife because its stuck open is another. My commander needs to go back for the second time and the lock on my dad's 13 is on it's way over.
The only problem I ever had with my Emersons was that they opened every time I pulled them outta my pocket.
Must be a design thing................................![]()
"I should have been more specific. Hand pressure on the the blade spine will cause the liner to work back off of the blade tang allowing it to close. I have had a couple of other locking liner knives release on me while I was trying to cut plastic crate straps. I got cut one of those times. Because of those incidents I like to test all locking liner knives with pressure against the spine. You would be surprised how many "tactical" knives fail this test, even high-end models. I also do the white knuckle grip test."
If you read carefully I said that I have the feeling that Ti is not the best material for a liner lock given the fact that mine failed and many others seem to be doing the same. I have had many liner lock knives that never failed after years of use and even abuse.
That said, mine failed. Emerson fixed it and I appreciate the service. I don't know why it failed as it is brand new and wasn't abused. I don't think it should have failed. I am not a knife maker or a metallurgist. I am however an engineer and I do expect a safety feature this simple to be reliable.
Going back a few posts to the one where his EKI was "gritty" that describes my new A-100.
The knife locks up, is centered, but after a week of carry time it's still a lot slower to engage than any of my Benchmades. I've played with the pivot where it's backed off without any play, but it's still slow to open without really cranking it with the thumb disk.
On the positive, it has loosened up a little bit...so do you guys think there's a problem with it, or do I just need more play time with it?
Any advice would be welcome.
You probably already have done this, but I'll throw it out there. Have you tried any lubrication?
