America has reached 250 years, and I am grateful to be here, in the best country in the world. Thank every one of you who helps make this country a better place, those who have gone before and risked it all, and those who've paid the ultimate price to make the United States what we are today.
A progression can make a big difference. The other thing that might hold you back if all else is in order - your strop should not be too conforming. In my own experience if my strop is not virtually solid then I don't get the best results with the finer particles. I've tried stropping on a hardwood board and it gave me poor results, so for me, it has to be something in between. I haven't tried balsa or MDF - yet. Currently I find with a 3 strop progression I can get to tree topping from a 400 grit sheet of sandpaper. From a DMT EF approx 1200 grit you should be very close with one strop, using an intermediate one might be the ticket for you. Also, the difference between hair popping and tree topping can be as close as a slight fine-tuning of your technique or a change-up to your strop material, and not necessarily your abrasive size. You're right at the threshold, just keep paying attention to cause and effect and you're sure to get there. One last bit of advice, once you get your basic skills strong start sharpening as many different knives as you can. Having to adjust technique to a variety of bevel angles and edge radii will help cement your muscle memory, form, and perception of feedback.
HH
Have you tried anything harder than balsa yet?
One thing I did and it made an immediate difference was to apply some paraffin to the leather of some strops I had around that I felt were too soft. I heated it with a hot air gun and repeated a half dozen times. I remembered that hot wax on leather is/was a common technique for hardening it up for use as armor or to firm up a sheath/holster. It worked like a champ and I wound up not throwing these old strops away. I can just dig a fingernail into it, otherwise it has no perceptible give when pressed with a fingertip. Edges glide across it with real good feedback.
HH
I just joined this forum because I am having the same difficulty getting a hair shaving, paper cutting edge on my knives. I am up to a Wicked Edge system now and still I can't get a knife shaving sharp. I spent 2 hours last night on a new knife I just got ( Ontario SP6 ) and it's no sharper than when I started.
After reading this thread I think I know what I have been doing wrong. I have not developed a wire edge on 1 side before I start on the other side and I need some magnification to see what I am doing to my blade. I have been concentrating more on keeping the strokes even on both sides.
It looks like I am further behind than you are okbow68, at least you were getting a wire edge. I will try now for a wire edge on each side and not worry about counting strokes and see where that gets me. Once I get it I will change the angle slightly with each stone using less pressure and take my time.
Let me know if it sounds like I am on the right track.
Congratulations on your sucess I am hoping for the same.
I did mess around with green compound (and some white, I think) on MDF a while back, before my 'skills' were worthy of it. I did notice how aggressive it was, as with the balsa, but I was still learning the process, and couldn't draw any conclusions based on my results at the time. My mind is gearing up toward using harder/firmer strops, so I'll likely get back around to trying MDF or hardwood again. I still have some DMT Dia-Paste that I'd bought a few months ago, but haven't cracked the seal on it yet. I've been surprised at how well I like the Simichrome, so I've been sticking with it for the time being.
I do like your idea about waxing the leather to firm it up. I'm betting it holds compound very well too.
Don't move to the finer stones unless that burr is all there. Also seems kind of slow just to raise a burr really. I mean, it doesn't take much more than 2 minutes for me to raise a burr on S90V and S110V using my WorkSharp.I got it sharper after working on it another 3 hours tonight. I could never get a burr from about 1" to the tip. I think that I need the 60/80 grit stone, it is just taking to long to develope the burr.
I need something finer than a DMT extra fine before the green compound possibly? what would be the suggestion
Okay you guys, I strop strop strop and am hair popping sharp but not tree topping or whittling hair. Would I benefit from going from DMT EF stone to say a 3 micron or a 1 micron paste and work it for a while and then down to the .05 micron green compound ? Thanks sharpmasters!
