- Jun 8, 2000
Ok, So I'm proving to myself that I really am a newbie. I had a plan. I went to Harbor Freight and bought a shiny new $99.00 bench top bandsaw for profiling the blades I intend to make, and while there got stylish $59.00 combo 1"x30" belt sander/ 5" disc sander (let's consider tis the first mistake). With a few files, stones and a cheap hacksaw I already owned, an old Craftsman Drill press and a bench mounted 4" vise and a 6" bench grinder (and the obligatory Dremel of course), I figured that I was set to make a modest start in knifemaking. I was hoping to financially ease into this hobby. I thought I'd buy a couple cheap machines and build a couple knives to see if I have any talent before investing big money in specialized industrial grade stuff.
I then went out to Tru Grit and met with John & Linda who own the place (real nice folks by the way) and procured a few feet of fine ATS-34, 440C 3/16" & 5/32 x 1.5", (here's my second mistake) and some handle material.
I should mention that I did study metalworking in school (way beyond basic metal shop, up through teacher's aid in the vocational classes) and actually worked as a machinist for about two years when I was a younger man This was before I discovered that I could make more and ache less in a sales job.
So at this point I've got my modest shop and I arrive home with the steel and figure I'd better get to it. So I measure off 8" of 5/32 ATS-34 and fire up the mighty Harbor Freight bandsaw. After immediately killing the blade that came with the saw as well as both replacements I'd bought just in case, I'd only made it 1/4" through the ATS-34! I'd even splurged the extra $20.00 to get a variable speed bandsaw to be able to keep the blade cutting speed down to conserve on bladewear. At this point it became obvious that this saw was going to do no profiling. Out came the cheap hacksaw. After much grunting and a few popped hacksaw blades (frame flex!), I finally had a workable piece of material in my hand (should have started with some 1/8"x 1.25" stock for first project). So I pencil an outline on the steel as I have still been unable to find a can of Dye-Chem layout dye. Off to that monster 5" disc grinder. It quickly becomes apparent that it's as big a piece of junk as the bandsaw. I knew not to expect to get the kind of performance that the industrial machines I learned on would deliver, but c'mon, these things were pathetic. So back they went (Harbor Freight has a good return policy and I really hardly used the things). I then went to Sears and got Craftsman's best hacksaw and a few more files and for now I'm working the old fashioned way. My first knife will definitely be "hand made" for the most part.
Here's the question: what kind of grinder might be suitable that isn't a purpose specific $1000.00+ knife grinder? I've given up on a bandsaw idea for now, but I do need a grinder of some sort. I'd like to stay under $300.00 and closer to $200.00 if possible. This is only a short term solution and if I take to this knifemaking thing and the IRS doesn't beat me up too much, a real machine might be in my future, but I need a workable solution for now.
Looking forward to your replies.
jmx
jmx
