- Sep 19, 2001
they don't have a single extra coarse, and I can't find a single 6 inch extra coarse, just the 8 inch-which is a lot more expensive. But, they have this http://www.knivesplus.com/DMT-Knife-Sharpener-DMT-FWX.HTML
I think they come with a little something, but that's what this forum is for, plus those links I gave you are pretty good. Just hold a fairly consistent angle, use reasonable pressure (whatever amount you can use and still maintain the angle) and use light pressure on your finishing strokes.
For most edge maintenance, I agree, but he's going to cut a new edge bevel in the spine of the knife, which is going to be much more work.You barely need to use any pressure at all on those DMT stones. In fact, I found if I put much more than the weight on the knife on the stone it leaves a very irregular edge (with my Fine and Extra Fine stones). I would recommend a C/F combo because diamond cuts very fast. I intially was going to go that route, but with how fast diamonds cut (dont forget to use water!) I'm thinking I can pretty much handle most everything with the fine/Xfine...
...but with how fast diamonds cut (dont forget to use water!) I'm thinking I can pretty much handle most everything with the fine/Xfine...
