Jason Ward
DISHONEST RIP OFF ARTIST
- Feb 12, 2022
Partially* predictableMaybe to heat plates before quenching to compensate thermal expansion in steel ? Expansion from heat in metals is predictable ?
Technically yes we would need to eliminate oxygen somehow. I am thinking about just purging an entire room with nitrogen and an evenheat. Can't be too difficult to cut a hole and stuff kaowool around a . Well shit idk what kind of valve would sustain those temps that's not 10k. I'll think of something.why not go with a positive relief instead of worrying about thermal expansion? Or just tolerate the plates not closing entirely. Does the assembly have to be enclosed around the perimeter to be a worthwhile experiment?
I squeeze a pair of plates vertically/laterally against the largest flat surfaces of my plate-quenched blades (trickier with tapered tangs, but doable). I do it upright to attempt to reduce warping from blades bending under their own weight (plus foil packet weight). Obviously there's an air gap between the plates themselves. I've taken to pulling air through the gap on the blade side with the shop-vac, where there's minimal contact there if I grind before heat. That way blades are less likely to warp (cooler) coming out of the packet. So it's a plate/air combo of sorts. I don't do it often enough to claim any statistical improvement, but it "feels" like it's helping.![]()
I know that many knife maker here in EU use tray filled with argon .Some manufactures of heat treat oven offer them also for sale .Pretty much everything I know what to do except I need to find something to expand and contract that acts as filler. Has anyone added nitrogen to an evenheat? Atmospheric pressure not 5 bar. Me thinks it's possible so why not? Additional easier test that again afaik nobody has tried it.
Mm. Argon is heavy enough that you can do that but you don't get the added benefit of nitrogen, argon will just slow oxidation, nitrogen has the potential to increase corrosion resistance and possibly form carbonitrides. Carbides = carbon nitrided = nitrogen. They *can* mix.I know that many knife maker here in EU use tray filled with argon .Some manufactures of heat treat oven offer them also for sale .
How you've hardened knives you make so far ?daizee Yes most of the research like this as you know is paid for by grants and is done specifically for a time frame result. That's science but. Ya I'll update the post when they decide to deliver my evenheat! And ya true N Natlek but how hard is it to make it a parallel flat surface? Trigonometry exists for a reason
N Natlek I've had to either send them out to be vac pressure furnaced at Peters' Heat Treating or sometimes I get to use my I wouldn't say..friend I guess um..buddy acquaintance would be a more accurate description, but he's got a forge and an evenheat lb18 which I have done only low alloy low hardenability varying microstructure from forging 1095 and 80crv2 like. 6 times lol. I'm more interested in the metallurgy and science side of this than actually the craft making part I actually hate LoL (I'm talking engravings detail shit handles etc not the blade, that I actually enjoy for some reason). I'm guessing that wasn't hard to know from everything that I have talked about since getting here heh. My point was that I'm a stock removal high alloy mostly high speed steels that gotta be PM or PESR manufacturing processed and I gotta know the rolling direction which is why I like Niagara specialty metals they cross roll their steel so there isn't a real direction. I'm not sure what others do that but it's something I would call about lol. I'm a little bit of a perfectionist ill admit. There's a lot of bad about that but some good stuff.Take some pictures while testing , we like pictures here![]()
Jason - i would strongly recommend against the "purge whole room with N2 idea. Itwould take a LOT of nitrogen. You likely would not be able to truly purge that space anyway, and it would be an incredibly dangerous environment to work inTechnically yes we would need to eliminate oxygen somehow. I am thinking about just purging an entire room with nitrogen and an evenheat. Can't be too difficult to cut a hole and stuff kaowool around a . Well shit idk what kind of valve would sustain those temps that's not 10k. I'll think of something.
Your positive relief idea actually is really good. Thank you!![]()
Now to figure out what to seal it with.
C Cushing H. I have the equipment to do it man I'm not retarded hahahaha but yes I really appreciate the concern I'm well aware it's not going to be cheap or easy but trust me I have a perfect space to do it. And yes, SCBA gear and a positive pressure level 4 biohazard suit so. 4 gas meter. We'll make it work. If I fuck this up. I deserve it.Jason - i would strongly recommend against the "purge whole room with N2 idea. Itwould take a LOT of nitrogen. You likely would not be able to truly purge that space anyway, and it would be an incredibly dangerous environment to work in
Oh I'm a whole nother levelSCBA gearAnd I thought I was weird
