Nice. Don't believe every thing you read on the forums. Even Sal himself gets his words mixed up sometimes. The fact is that early Millies do have eccentric pivots. It is physically impossible for an eccentric stop pin to rotate while tightly nested in a liner. I suggest you examine one yourself.
Bo
I don't see the problem here. You corrected my mistake and I agreed.
:thumbup:
edit ...
From Joyce re: Ecc. pivot pins.
"There was a cross over time where we had started using S30V on the C36 and were still using eccentric pivots. We stopped using eccentric pivots early this past summer and the Military's pivot pin changed then to a "D" nut. It actually came about as an improvement in our manufacturing capabilities. The tolerances on parts used in the older Military were tight but we've gotten better. We installed an eccentric pin so the knife could be adjusted for any tolerances that were not absolutely spot-on precise. With recently upgraded machinery (and a really talented crew) in our plant, we're cutting parts to even closer tolerances eliminating the need for adjustment. Probably seems rather strange, but we're getting better at making 'close to perfect parts'.
Joyce @ Spyderco"
When was this? My problems with poor tolerances on the lock appeared sometime early 2008.
To the people complaining about the Military liner lock; have you ever had the Military fail or close on your inadvertently? I don't want to hear about some cheapo liner lock during use, just the Spyderco Military. If the answer is no, then you're making an issue out of thin air.
I think it was Singularity who posted a video with the torque disengagement and it's something you can replicate on your own (twist the handle while putting pressure on the blade). I've also found squeezing, light spine taps and hand pressure will disengage the non-flush locks fairly easily. Some Millies I've had have been the absolute poorest in terms of lock strength compared to other knives of mine.
Have I accidentaly had one close on me and it cut me? No, but I'm very cautious about not stressing the lock on those with poor QC, and even more so than with cheapo chinese folders that often have thicker and more precise locking surfaces. It's harsh but true and believe me I wish it wasn't. :foot:
Any lock where two pieces of metal meet will wear. How is the lockbar catch on a lockback any different? Is your comp lock tab impervious to wear?
There's been a few threads in the forum where people have asked if their lock is ok because it travels so much. The standard answer is usually "yes it's normal, the Millie is the best knife in the world" (yadaýada) but what I've personally found is that the locks that aren't flush will travel very quickly to the point on the tang where the angle gets steeper, and then travel some more because it's still molding to the tang. Anywhere between 60-90% travel in very short period of time is not unusual. :barf:
Sure all locks will wear but some locks will wear faster.
I agree that the comp lock is great. But with gloves on (or even without) the Military still feels much more intuitive and easy to manipulate. I don't even like Emerson knives, but they're widely regarded as very tough and hard use. Oh wait, a liner lock out of a material softer than steel? Haven't heard many gripes with that. I've beaten the tar out of my Military for the last year, and I'm just not seeing these issues in this thread.
The Military's design is great, but like the Manix and Para QC is sometimes lacking. Blade play is one thing though (eventhough the Manix and Para both had a redesign to fix their locks from failing horribly), but a weak liner lock is another thing all together.
I agree in most cases it wont be an issue and 99,99% of all users will never put any real stress on the knives because they are cutting tools, but a knife like the Military where it's first and foremost a tactical blade "normal usage" is a moot point (and one I'm quite frankly getting tired of hearing with other Spydercos as well).
I really don't want to be the one to have this conversation because it's so easy to become protective of both since they're special and without substitute for a lot of people (and I'm one of those people) - but the fact is that in my experience the Millies lock has tons of room for improvement... :thumbup:
