If you could change a dimension or size of any Spyderco model...
Check out the Caly 3.
If only it was still available in G10/VG-10. However, one of my favorite quotes about the Caly 3.5 came from a member on the factory forum. He said that it was almost a Delica in handle length and almost an Endura in blade length. And he was right in every sense. The 3.5 only has 1/8" more handle the the D4 and only 1/4" less blade than the E4. It's quite possibly the perfect EDC knife and it is still available in G-10.
Southard with thinner stock and ffg would be a dream. Maybe thin the handle down a tad so both sides are even.
Techno that's scaled up with a larger pivot and longer handle and blade.
Gayle Bradley that's a frame lock with a thicker stock and ffg.
3.5" bladed native 5. Perfection. Maybe throw in a bbl (not cbbl).
Larger dodo (well, I just want it bank in production)
Maybe a longer techno.
The DF and Also the Techno. I Love the dragonfly and the caly does come close to a super sized version but I would like to see the dragonfly larger. The Techno I love the design of but I run out of handle.
I'd like to see Spyderco bring out some knives in the lower price range of the Delica/Endura with the narrower profile of some of the above referenced knives.
A good example of width is Southard vs. Domino at 1.22" and 1.46" respectively when measured at their widest midsections.
Personally, the best example of a functional but flush Spydie hole is the Memory by Frank Centofante. They pulled off a classic Gentleman's pocket knife while easily identified as a Spyderco.
I'd love to see a Techno with between 3 and 3.25". Blade stock at 75% the current thickness and with a lock bar insert. The bradley air scaled up by 25% would be a dream also.
I'd like to see a up-scaled Domino that is no smaller than a Manix 2, and possibly as large as the Manix XL.
I would also be interested in a Micro Military, a smaller PM2 around the size of the Delica.
Pingo that is slightly bigger ..... Say with a 3 inch blade. Same design just overall scaled up.... Maybe a lock.
And don't say they already did the rock lobster lol..... Similar but not the same
Caly3 and clipless Kopa with 2mm thick solid ZDP189 blade
Native 5.5 with FFG 204P 3.5" blade.
A 2.5" blade Jester. Would be a perfect companion to it's smaller counterpart on my key chain.
Make it 3" and I will buy it.
