Well like 5.56 said, I've had a fair few Leafs, 3 total, plus I've handled his.
Of the 4 Leafs, only has has really impressed me with fit and finish. It locks up perfectly, and looks great.
That is IMO the perfect Leafstorm. Btw, the lock does not slide over with any decent amount of pressure, it is tight where it is.
This is a Leafstorm that came off e-bay about a week ago. Like the first Leaf that came into my hands it has a lockup like described by the OP.
The first picture is with the lock just nestled in it's spot after a gently slow opening being extra slow right as it clicks in. The second picture is after light pressure was applied the the blade (about what you would do cutting cheese) and the lock was lightly pressed by the tips of my fingers the way I would hold a knife when I was cutting something. (like cheese)
You can see it presses over fairly far relative to the starting position, you'll also notice that it appears as if the right top corner of the lock bar is slightly pushed outwards into a lip, I have noticed that as long as I have owned the knife, it has a tight lockup that is not very smooth. It also exhibits the titanium on sanded S30V sound when the lockbar scrapes across the lock face when pressure is applied to the lock or to the blade. As when gripping or cutting.
The first Leaf I owned had less lockup than the second one pictured, it locked up roughly 10-20% of the lock bar, not even 10% of the lock face was engaged. It also easily slid over with the metallic scraping sound when the blade was pressed or the lock face was pushed lightly.
Here is another little caveat on the eBay Leaf you see in the second picture.
You can see part of the screw is sheared off the edge of the countersunk type head.
This may be a test of Spyderco CS sometime soon.
