- Jul 30, 2006
According to Felix Immler, the package hook is popular in EU, because there they do still commonly tie up packages with string there. And I would recommend that you watch his video on the various other purposes for which it can be used.
That being said, my most used SAK is a Small Tinker. And if I could only have one, it would be that one. It disappears in the pocket, but is always there. And I use the screwdriver and can opener/driver blades at least as often as I use the two knife blades.
The screw driver works as both a screw driver and a light duty pry bar.
The can opener has a thin hardened protrusion which will reach into thin groves when I want to pry and not cut, and the screw driver blade is too thick. It also works great for pistachio nuts, when the shells only pop open a small bit, and you can't get finger nails in.
And I actually do use the phillips head screw driver for its intended purpose. I live in an old house. I sometimes find screws which have loosened up. I use all three screwdrivers depending on the type of screw.
Several years ago I lost a lot of weight. Rather than buy new belts, I shortened my old ones and made new buckle holes in them. You know I have several knives with awls. I found the ones on the SAKs work well.
I have half a dozen or so SAK variants. The Small Tinker is the one I need.
