Jason B.
- Jun 13, 2007
I get my leather from http://www.handamerican.com/ the site is under construction right now but i think you can still call them
Well it's back to the rice paper for me. It's a clean cut through the hair, but I have to chop a little. I'm a little confused now on what my goal is now. I thought I wanted a clean cut which is what I get, but now I'm thinking I'm supposed to somehow slice length ways a bit.
what strops are recomended by the kung fu masters?
Try it with a razor blade taped to a stick or something. (I've actually never tried this.)
This is the one I use and recommend:
http://www.knifecenter.com/kc_new/store_detail.html?s=J30
(Except it was only $20 when I bought it about 5 years ago.![]()
I use this conditioner on it first:
http://www.knifecenter.com/kc_new/store_detail.html?s=J55
The paper on glass surface is more perfect than leather, and there is less give to the surface. I find that I can strop right on the bevel just based on the feedback feel.
Question # 1, Do you use it back by something? I think I remember you said that you do.
Question # 2 I found a very nice quality 2" leather strap that is only about 1/8" thick. Both surfaces are quite uniform and the thickness is also quite uniform. I chose it primarly because the thickness was so even and also cause I thought the thin strap would make the flattest surface plane to strop with (backed with wood). Can you give me any feedback, positive or negative on trying to use such a thin piece for a strop? Incidentaly the nappy side was a bit rougher with smaller more uniform "grit" nap than the other leather pieces I saw. I thought this would be more effective for my rough side.
Question # 3 I have seen several mentions of using plate glass for sharpening and stropping, but I haven't seen any reference to using flat iron, say 1/8" or 3/16" thick. If not for stropping on a hard surface, then how do you think flat iron will work for glueing the leather to?
I have some knives that were sharpened with an edgepro, so they have perfect, straight bevels with no micro-bevel and no convexity. I can strop an edge like that and clearly tell when I'm flat to the bevil or deviating either too high or to low. I usually try and just match the bevel, .
1. I use the arm of the sofa. It has a little give to it and it's convenient for me while I'm watching TV.
2. Sounds good.
3. Personally, I'm not crazy about using hard surfaces but other people have had mixed luck.
Can I take a few swipes on one side, or do I need to alternate sides with one swipe at a time?
