JT and anyone trying end grain scales:
The pattern is often stunning on end grain, but there is no stability there. Balsa wood and oak have nearly the same strength on thin end grain sections. All wood will move to some degree, even stabilized wood, and when it does end grain will crack. You can treat it just like mammoth tooth, which is just end grain tooth material. Back it with a reasonably thick and strong substrate. First, stabilize the whole thing with all the thin CA it will absorb, then sand the back flat and laminate to the substrate. Flood cracks as they form in sanding/grinding with more CA, don't let it get hot (or even warm) while grinding and polishing.....and expect cracks to form after the knife is done.
JT's scales are already cut, so all he can do is hope and pray. If anyone is planning on making end grain cuts to gain a unique pattern - before cutting the scales, have the board stabilized by one of the heavy impregnation methods. WSSI and K&G do this, some other "stabilized" wood is not done the same. Use blocks that have an end profile the size you need, and are at least 4-6" long. Cut the scales after the block has been stabilized. Realize that you may pay for some expensive stabilization and receive a split or cracked block back from the stabilizer. It is the chance you take...not his fault.
There are several woods that are end grain cut because that is the best looking pattern. B&W ebony, black or red palm, sucupira, and many burl blocks are just a few. One trick that still shows the pattern (and often makes it more interesting) is to cut the end grain at 45 degrees ( sometimes on both axes). This allows you to use a narrower and/or thinner board and makes the lignin fibers a little longer for more strength. A 1X4" board can be angle cut to get 1.25X5" scales. In the case of black palm, instead of just dots, the scales will have heart shaped speckles. On B&W ebony, the pattern will stretch out a bit, and the dark stripes will widen. There are some tricks involved in this. The main one is that you have to make two sets of cuts. One for left scales and one for right scales. If anyone needs more info to figure that out,ask and I'll post it, but I think if you have the equipment and ability to do compound miter cuts, you probably have enough woodworking skills to figure out what I am saying.
The backing you epoxy the scales to must be strong and stable. While vulcanized fiber is often used, I think a thin section of linen or canvas Micarta may be a better material to use.
Just some info and food for future thought .
Stacy
