Well, not really, I love my puppy. But I am frustrated.
I've just set up my evenheat kf 27. I am trying to HT some 1084 I got from Aldo. Here is a video of my initial attempt:
[video]https://youtu.be/oBE5BbijeAA[/video]
After the video I took the blank home and put it in my oven at 400 deg for 2 hours, twice. The next day I showed it to my machinist friend who had a file and hardness tester. Both indicated that my blade blank was very soft.. about 32 RC. I thought perhaps I had tempered it too far, but it turns out that my problem lies with the HT. No matter what I've tried, I simply cannot get the steel to harden.
I'm heating the blade blank to 1500 in the kiln. The blank is balanced on its spine on the floor of the kiln near the door (I don't have long tongs yet). I let it soak for 5 min to make sure it was evenly heated, then remove it with a pair of pliers and quench in canola oil preheated to 130deg. I agitate it back and forth until the bubbles stop then let it sit in the oil.
I'm borrowing a friends ancient hardness tester. It is consistently 3 RC soft on the calibration test blocks but it still gives me a ballpark RC on my blades.
My blades are registering low 30's to low 40's RC every time. I've tried several pieces of 1080, 5160, even a block of 1045. Always soft.
On A whim I quenched a blade blank and the block of 1045 in water and warped the crap out of the blank but it did get it full hardened. The 1080 was about 64 RC and the 1045 was 60. This was from 1500 deg. Of course now I'm doubting the RC reading.
I thought that perhaps I didn't have enough oil to dissipate the heat so I added an additional 2 gallons. It didn't seem to affect anything.
To make sure the steel was up to temp I increased the soak time to 20 min. Fail.
Worried that my kiln wasn't reading the correct temperature, I tried increasing the temp to 1550, then 1600, then 1700 before quenching. Didn't make a difference.
I thought perhaps the kiln wasn't heating evenly, so I tried pushing the steel further into the kiln instead of just by the door. NO difference except now I have no hair on my arm.
I tried quenching in used 10w30 motor oil. NO difference, still soft and now my shop stinks.
I wondered if perhaps the Hardness tester was off or I was using it wrong so I tried a file instead. It ate into the steel like it was annealed.
Before testing the hardness I'm grinding off all the scale down to shiny metal to avoid a bad reading. I've even cut deep with a file just in case only the surface was soft.
This is my first attempt to HT on my own. I've been experimenting for 3 days now. I've consulted with two knife maker friends to no avail.
I am doing something fundamentally wrong but I can't figure it out. I can't even tell what details I'm observing are important or relevant. In fact whatever I'm doing wrong is so stupid I managed to stump Tai Goo.
So I am throwing myself to the mercy of the Board; the person who posts a solution to my problem will receive a special prize...
