UPDATE... Breakthrough!
I left my shop well after midnight yesterday feeling pretty good. I think I've identified my major mistakes.
1. I wasn't letting the Steel get up to kiln temperatures. I made some test medallions from the 1084 and put them into the kiln at about 1300. When the kiln read 1500 I opened it up and to my surprise the steel was still magnetic. I did not give the steel enough time to catch up to the kiln's temp. My solution is to allow the steel to heat up with the kiln from room temperature whenever possible. Because I was doing back to back tests without allowing the kiln to fully cool I compensated by increased soak times and testing with a magnet.
2. For whatever reason the Canola oil is not quenching fast enough for the 1084. I could consistently reach full harness with a water quench, conversely I never got above 40 RC with oil quench on the 1084. However the canola oil did work perfectly with some 5160, reaching full hardness well above 63 RC. I need so study up on how to properly use canola oil for quenching, including preheating, volumes, and agitation.
Materials: I checked my emails and confirmed that I purchases
1084 from Aldo... in 2013. That is all the evidence I have that it is indeed 1084. I had that bar laser cut into some machete blanks. One of which I ruined on the grinder and threw away in disappointment. The other I broke hitting it against a log before any normalization or HT. I made the new knife blade blank from that broken machete blank. And I still have the skeleton of the bar. It is from the skeleton that I cut the test medallions.
Methodology: Discovering the medallions were still magnetic even though the kiln was at 1500 indicates that my assumptions about how long it took the steel to get to temp were waaaaaay off. By the time the kiln read 1650 they had caught up and were non magnetic. I quenched one medallion at 1650, and one at 1800 in the canola oil. These quench yielded the softest results ever, reading less than 20RC for both pieces. I ground half of one of the medallions on the belt sander (both sides) down about .050". I tested the ground end and the non ground end see if there were any changes in hardness deeper in the steel. Harness test on both ends were identically soft.
I then put the medallions back in the kiln and let them heat up with the kiln to 1500. This time they were put in early enough to heat at the same rate as the kiln. I checked them with a magnet and then quenched in water. Both medallions tested at over 63 RC. So the water certainly worked.
I then put in some blade blanks. One small blank in 1084, one medium in 1084 (the one I originally wanted to finish) and an old monster of a chopper in 5160 (that I got from Admiral Steel). I let them all ramp up with the kiln to 1500. I quenched the small blank in water. I quenched the other two in canola.
The small water quenched blank in 1084 was over 63 RC. The oil quenched medium blank was mid 30's RC. The Oil quenched 5160 was about 58 RC.
I read up on the 5160 and realized that I didn't give it any soak time. So I ramped it up again to 1500. Then I let it soak for 20 min. I made sure the Canola oil was at least 135 by heating the side of the ammo can with a torch while I watched the temp with an ir thermometer. I quenched the 5160 in the heated canola oil. It came out at over 64 Rockwell. Success.
So I can get expected and repeatable results with the 5160 and the canola oil. And I can do the same with water and the 1084. And though the results from oil quenching the 1084 is not expected, they are consistent and repeatable.
Some random observations and info: A couple of times I quenched the larger 1084 blade blank and the 5160 blade blank in water. It warped them but still got full hardness. Oddly enough the warp largely disappeared just by heating the blades back up to critical.
And yesterday I found these at Harbor Freight:
http://www.harborfreight.com/16-inch-long-reach-pliers-set-38598.html They have been working great as oven tongs so far.
