Square_peg
- Feb 1, 2012
If you're there to do a job, sometimes you gotta just use the right tools, easiest to carry or not
But it helps if you have a mule team to carry your gear.
If shopping for a vintage axe True Temper and Plumb are safe brands. Look for an axe with a long toe, a sign that it hasn't been heavily worn. Also look for poll damage, you don't want an axe that was used for pounding steel wedges.
One last, convex cheeks, also called a high centerline. Flat-cheeked axes are sticky. They don't pop the chip well. I don't know if anyone has made a good convex-cheeked axe since the 70s or early 80s. Council's Velvicut is probably the closest thing.
jersey_bits by city_ofthe_south, on FlickrRandom thought because I like to modify everything .... not that it necessarily does or doesn't fit your needs but I happen to think 3lb axes are pretty dang handy outside of real serious wood chopping/bucking. It might be possible to take a new axe, like a Council Tool and grind a bunch of material away from either side of the cheeks, thin the bit overall and reduce the poll down to nearly 3lbs. This would raise the cheeks to resemble older made axes, and reduce the weight. Whether or not you could get a half pound out of a 3.5lb head is the question. All of the 3lb heads I have are roughly the same side profile of a 3.5lb head but in every other dimension are thinned.
Example; 3.5lb heads on left and right, 3lb head in the center. All 3 are Jersey patterns.
I think a good starting point for the length of someones personal axe is measure the length of your arm. As if the axe head is in the palm of your hand and the palm swell is in your armpit.
I've always found 36" handles too long. Either over striking or afraid I'd take it in the nuts if I choked up too much on the handle.
I'm 5'6" and 160lbs. A 26 inch handle is just the thing for me when spitting wood.
I can relate. I'm Forest Service certified to operate chainsaws or crosscut saws on any Forest Service land. Up here in WA we re-certify every 2 years. The certification program started by the Back Country Horsemen of Washington was actually the pilot program for certifying sawyers for FS lands. We were the first one
All that said, I'd still look for a 2-1/4 to 3 pound axe on a 24"-30" handle for your work. A Hudson Bay would work but they will work loose under serious work because of their short eye. That's why I prefer the boys axe, longer eye.
If you could find a 2-3/4 pound axe like my Walters and put it on a 26" - 30" haft I think it would serve you extremely well. If you also wanted to use it as an underbuck then I would want at least a 32" haft.
Steve Sr. - Welcome to the forum!
My favorite saw comapnion axe - for last weekend anyway (026 Stihl, logging out a trail in medium sized fir) - is a 2-1/4# Craftsman boys axe, hung on a 28" crusier double bit haft.
I want a straight haft for driving wedges, and by doing a little work on the tounge most of the "fat" replacement hafts available today
can be made to fit nicely. Finished length usually ends up between 26 to 27". Total weight is just over 3#.
If working in big timber, or doing any felling, I usually carry a 3.5 or 4# on a 32" straight haft. If your packing a 046 Sithl with a 36" bar, or a 7 ft. crosscut saw, the extra weight dosen't
seem to matter as much, and your swamper can help!
I would like to see a picture of your backpack!
Is your Walters a vintage head or is it still available?
I have noticed that just about all of the boys axe heads that I have seen on the Bay are pretty thin cheeked. I guess that this gets rid of the weight without reducing the size much. From what I have read the thinner cheeks make the axe more likely to stick and less likely to eject the chip. Is this usually much of an issue?
truetemperFEKW_connie2 by city_ofthe_south, on FlickrI had a 1.75lb 26" axe as a chain-saw assist for one 9-month work season. Heavy enough to drive wedges, light enough to swing one handed when needed and not too much of a hassle to haul around. 15lbs of chainsaw, an extra half pound might not make a difference.
http://www.canadiantire.ca/en/pdp/garant-chainsaw-axe-26-in-0575135p.html
http://stubai.com/index.php/en/forestrytools/n-6715-stubai-chainsaw-axe-canadian-type-detail
Those aren't bad choices. The Stubai steel is very good. The Stubai handle will be a little harder to replace since it's not a standard American handle.
But those both have flat cheeks and will be less efficient choppers.
