Unless you really really need to weld aluminum I would avoid looking for that option just because it adds a lot to the complexity of the machine and the price. When I was looking it added about $1000 to the machine. I checked out the little Eastwood and that would probably work great for what you need. If you can find a option that has lift arc or high frequency start but doesn't have a foot pedal it would give you maximum value. Foot pedal is needed for aluminum and ultra thin materials but is rarely used for other steel tig work. I would recommend getting some 3/32 E3 purple tipped tungsten although the red thoriated is fine. You will also need a bottle of argon and a regulator. I prefer a flow meter over the guaged type.
I can't run a TIG without a foot pedal. As far as I'm concerned it's not possible and it's just a joke pipe fitters and the like play on the rest of us, like mechanics and blinker fluid or boy scouts and cans of dehydrated water![]()
If you use a scratch start you have to touch the elctrode to the work just like stick welding. The problem with that is that sometimes your tip sticks and you break it off and it contaminates your weld and screws up your tip all at once. Lift arc senses when you touch the work and turns on the power once you lift back off. High frequency has a separate high frequency (high voltage) that leaps the arc gap and allows you to start without touching the work at all. If you are doing aluminum its AC so you run high frequency constantly in the background to hold the arc path open. With steel the high frequency shuts off after the arc is started. HF is nice but I would recommend at least lift arc as a option.Okay, there is another set of questions. The ones that I am looking at appear to have lift arc and/or HF start. I just had no idea what that meant. Still don't, but at least now I know that it is a good thing.![]()
Well I have an Everlast Power i-TIG 201 and an i-MIG 200E on the way, so I'll let you know soon. One is being delivered today, but I don't know which one. The other hasn't shipped yet. They're each ~$500 machines.
Electrode burn back is either no shield gas ( you will see white power and burnt areas ) or elctrode positive. I don't know why I'm telling you this. I'm having problems with mine when doing high frequency pulse on aluminum and not switching from high frequency start to high frequency pulse and it balls the elctrode while it is switching. I'm not sure if it's a setting issue or a controller issue. If you have problems with your next one really get into any hidden menus to see if there could be a problem there.The Everlast MIG developed a problem right away. The gun was staying live even when the trigger wasn't pulled, so if you contacted the wire to the work, it would burn back to the tip. The welder still worked, but that's not acceptable. I contacted Everlast and within a day I had a return UPS shipping label to send the inverter back, and they sent me a replacement.
Both my replacement MIG welder and my TIG welder that was backordered arrived yesterday. I hooked the new MIG up and just welded a couple beads on 120v with .035 wire to test, and it works great.
The TIG is a Powerarc 160. I set it up but have no Argon and no tungsten so I haven't done anything else with it. I've got some thoriated tungsten on the way and Friday I will fill both my 75/25 bottle and my Argon bottle when I go to get more liquid nitrogen. In the mean time I'm running a 220 circuit for the welders. So hopefully this weekend I should be welding with both units at full power.
I was up late. Sorry. LolYou're misunderstanding. The MIG gun was live whenever the welder was on, like a stick holder. It would burn the wire off because the wire feed wasn't on unless the trigger was pulled. That's just not functioning properly. There were no menus, it's an analog machine.
It happens. It was still a good looking knife though.Yeah, Kuraki runs a very large steel fabrication company with a few hundred employees. He knows how to weld, I have seen once where he didn’t read the tape measure correctly though.
Hoss
Hoss
Hoss
