If you see some try that new E3 tungsten. It can be cheaper than thoriated and runs very nice. Also if you have high speed pulse on your welder it will run the best. Thoriated can split with high frequency. I let my students try all the tungsten alloys and they all had the best colors on stainless with the E3.I've run 220 and picked up some thoriated electrodes. First project with the TIG will be sealing up 416/cfv san mai for a dry weld in my mini atlas, so just doing a fillerless weld on a rebar stud to show how that looks. This was all done at 100 amps with a 3/32 electrode using the thumb switch and hf start.
It is a tri mix. Lanthanium, zirconium and yttrium. It has a super stable arc but the zirconium allows it to handle a lot of power. It's the only blend that really seems to compete with thoriated. It may not be as rugged as thoriated for scratch start field welding but I would recommend it as the best choice for shop use. One the price is better and then it works with inverters and is AC friendly. Also if the radio active thing ever becomes a big deal it is safe. Its not like its magical but it does run really nice.Is that "e3" lanthanated?
Thoriated is still really good. They are just getting hard to find sometimes. Unless you are using something that pulses the current rapidly they are the best or near the best depending on what you are doing. There is zero advantage to pure anymore. The E3 is great dor AC but if you you are going to be doing thick parts nothing lays down power like zirconiated. The only problem with it is that it doesn't focus the arc well for DC welding.I'll give them a try. I bought thoriated because it's all I've ever used other than pure.
