- Jan 22, 2011
Are you certain that chip was not there prior to your trip? I only ask because 1) this blade was previously owned 2) the damage is pretty small and you may have just missed it on previous inspections 3) the activities you mentioned would not generally be touching that area of the blade, much less stressing it to the point of damage (unless you sharpen sticks with the tip of the blade...).
Anyway, I would say your expectations are not too high. My guess is that damage was done prior to your trip and not just from contact with wood. In the end, it hardly matters because as others have said, the shop will take care of it.
What kind of sheath did you put it in after use? I'd wager if it was kydex there was some grit in there that contacted the edge on the way in.
I've got a kydex sheath from David Brown. But certainly some grit in the sheath shouldn't bang up the edge like that right?
It's probably due to a wire edge or some steel that's bent back and forth too many times. I'd be willing to wage that if you did a full resharpening and if you clean out your kydex sheath --- you'll have no problems. Keep in mind though -- INFI is still metal and when metal receives enough stress it rolls, chips, waves, etc.
