- Apr 3, 2001
No way INFI should chip like that cutting wood, unless you hit rocks or some other inclusion in the wood. Either bad heat treat - in which case you'll find out the next time you use it (I doubt this is what it is), or it's a slightly "singed edge".
I've seen it happen. Just sharpen it a couple times. I wouldn't waste all that steel peeling it back until the chips are gone in one session. Just sharpen it once, use it as normal, sharpen it again when it needs it, and it'll be gone. On a big blade I don't concern myself with sharpening all the small dings out. If you do, you'll quickly have an arsenal of toothpicks.
All that stuff will correct itself as you continue to use then sharpen the knife...
Or if you can always send it in if you want it perfect again. Best of luck to you whatever you choose to do.
