I have quite a few INFI, CPM 3V, A8mod, Cru-Wear(family), Z-Finit, etc. steels. I like Infi because it is tough, easy to sharpen/gets SHARP with ease, and good corrosion resistance. That said, it does not hold a great edge for cutting, but does hold a good edge for chopping. Also, when taken down to 20 DPS edge, I get edge deformation. So I convex the edge, or keep it at 25DPS, and it still performs very well.
At around 17 dps this is INFI vs 5160 at a similar thickness (5160 definitely thinner overall, but with very slightly more open micro): Same chopping on same Maple wood:
Quote: "As a specific example, in Cook's book (1921) you will see the edge angles of a swamper axe at 17.5 dps. If you scan modern small folders, 17.5 dpi would be considered a low angle - however this is a full size swamping axe, and these were the utility axes used to cut limbs roots."
Below: CPM-3V vs Chinese 420J (420J2: 0.3% Carbon, 420HC: 0.4-0.5%), same edge thickness, same angle (about 20 dps w/no micro-bevel), some careless twisting on the Chinese knife (the one folded spot grabbing nail fuzz), every motion otherwise kept dead straight on the GSO-10 in CPM 3V :
Gaston
