If s30v is so fragile how do you account for this?
http://www.youtube.com/watch?v=gqB3uQu8HCU&eurl=http://knifetests.com/page7.html
I think it's clear that the heat treatment is the deciding factor in S30V's performance, and that it is a very capable steel.
S30V is a stainless CPM steel, that has good edge holding. It isn't bad for Folding knife use. It absolutely sucks for fixed blade hard use, as it is not a tough steel by any means. INFI is a hard use steel that holds an excellent edge, is extremely tough and has extreme abrasion resistance. It is not nearly as corrosion resistant as S30V. If you are going for a light duty folding knife S30V is adequate. If you are going for a fixed blade INFI is the only way to go. Really, these two steels are not even in the same class and I am not sure why you would pick S30V to compare, as it seriously lacks toughness.
Is there a special way to sharpen S30V to get the best out of it? I seem to recall reading it was more difficult to sharpen than other steels? (Could be wrong though)
Just so I got this straight.
The S30V in your Strider has performed well. But you want to know if there is a problem so you can upgrade.
I battoned my Sebenza through some wood yesterday, hacked limbs off of a tree, the other day I made 100+ cuts through the Christmas carboard and haven't touched it up yet. There are no micro chips, there's no loss in edge performance.
I took my SFNOLE out yesterday too and beat the livin' crap out of the Christmas tree. It too is fine after a good chunk of abuse.
I'd say they're both pretty good.
S30V in hard use knives is crap. Pretty much any stainless steel in hard use knives is crap. Stainless has it's place, but it's not on hard use knives. Folders yes.
CPM3V is a whole different story. Arguably the toughest of the CPM steels and one of the toughest steels made. This subject has been killed to death. There has been mixed results with CPM3V as far as how great it's toughness is. Cliff managed to induce failure in 3V where he had never been able to in INFI. Cliff also destroyed the basics M-INFI, but it took 2 years plus grinding it down until the knife did not look anything like the original Basic7. I have chipped 3V myself and broken the tip off of a custom 3V knife, where I had not done so with INFI doing the exact same thing. The knife I had, had been HT'd by Paul Bos, who is one of the top HT'ers in the country. I am sure that properly heat treated 3V can hold up to whatever abuse most people would pile on it. As long as you don't plan on batoning it with a hammer you should be ok, and really, you should not do that with any steel unless you have no choice. As it as tough as INFI, no and it has been proven. Is it as tough as S7(scrapyards derived steel called SR77), no on paper for sure. S7 has considerably more toughness but looses it's edge faster.
Just to give comparative date, not exact of course.
S7 = 92.2 ft-lbs Charpy toughness at an Rc of 60 (125ft-lbs at Rc of 57)
cpm3V = 70 ft-lbs at Rc of 60
A2 = 40 ft-lbs at Rc of 60
S30V = 10 transverse and 25 longitudinal ft-lbs at 60 Rc
as you can see S30V is far below A2 which is the weakest of these steels.
I'm sure everyone has a story of their favorite steel doing fantastic things and other steels failing. Remember that one guys custom shop SFNO's broken tip? Or the other guys broken tip on his Ratweiler?
CPM 3V and INFI are both great. Eric Fehrman uses it for his blades and they can take a ton of abuse, as well as Jerrys INFI.
One thing is for sure in what you said, this subject has been killed to death!
I am looking for the perfect blend for a folder. What steel is the best for ease of sharpening, edge holding, durability, cost for a folding knife than?
Personally, I can not STAND CPM S30V. It chips, it's bad for chopping, it stains... I hate it. INFI, in my not so humble opinion, is the best blade steel on earth.
Anybody have any Charpy toughness data for INFI?
