Cobalt
Platinum Member
- Dec 23, 1998
Yeah, but, those were probably soft bolts though
A Busse blade that can bend 180 degrees without breaking and cut concrete and steel bolts in half! Who knew? LOL.......
I think part of the extreme bend is sword geometry, width and length. The reason why it can be bent that far. If that was a 2 inch wide 10 inch long blade it likely could not get anywhere near 180. probably not even half that. The bolt cutting is also sword geometry which is a very thick edge. Along with the hardness.
As a reference, here is a Busse Basic breaking point at maximum bend (57 degrees approx). This is what INFI became after the first run. This is at Rc 59
Then this is how far the original SHBM went without breaking. This was with 1% cobalt and .7% Ni, which obviously made the difference. This is a big difference in bend performance between the two. Also, the SHBM needed a pipe to attain the bend. That's the lateral strength difference. Which means the SHBM was stiffer, so it was stiffer and bent further. This is at Rc of 61+
