The linked article is about hardness, not a comparison of stiffness for various steels.
Hmmm. I think we are talking about different things. Or maybe I've lost the track of what we are talking about. For one, we don't really care about non HT'd steel. All knives are heat treated. More importantly we need to acknowledge that heat treatment doesn't change the stiffness of steel. I think that is all the article is describing, what stiffness is and what it is affected by, as well as some misconceptions that people have. Since the fact that stiffness is not affected by hardness or a choice of steel (within the application range we care about, meaning knives) is counterintuitive and many incorrectly believe otherwise. In any case the article is there as well as are other articles, so all the information is available freely, what to do with it is up to an individual.
I read what you wrote I just didn’t think it was relevant since we only care about a relatively small subset of steels and very narrow range of hardness. I also didn’t really realize what subforum we were in I just look at new posts and I like steel discussions, so chimed in. I believe you that this subforum is special in a good way. Steel should be discussed everywhere on a knife forums in my opinion.So, I talked about non HT metal because that is the example given in the article. But I don't think you read what I wrote. HT doesn't affect stiffness prior to plastic deformation. After it does. And the point of plastic deformation is quite different depending on the steel and the HT.
But the most interesting thing about all this is that there is no other manufacturers forum where this is discussed except maybe spyderco. Try to talk about this on any other forum like buck or CS or any other.
Otherwise, I agree in the elastic deformation range HT doesn't matter. When it comes to youngs modulus.
I feel discussion is good. I just feel that to much emphasis is placed on certain scientists and the context is wrong. I believe the article quoted is not as relevant as purported. Simply because it does not discuss plastic deformation. It discusses light loading and elastic deformation. That was my point.I read what you wrote I just didn’t think it was relevant since we only care about a relatively small subset of steels and very narrow range of hardness. I also didn’t really realize what subforum we were in I just look at new posts and I like steel discussions, so chimed in. I believe you that this subforum is special in a good way. Steel should be discussed everywhere on a knife forums in my opinion.
I am really not interest in arguing I was just trying to correct some misconceptions that seemed to be happening, but if you know all this feel free to ignore me. All the information and data is available through Larrin’s and others amazing work, so anyone who is interest can easily educate themselves.
I had mine measured and it was 60 to 60.5. That seems to be outside of the margin of error for a sword intended to be 62. I wonder if there are actually any of these at 62-63?
I messed the format up.beachmaster please don’t edit what I wrote in a quote, as it looks like I wrote this which I didn’t. All steels that we care about in all conditions we care about have the same stiffness that’s the point. Hard to write an article about it.
This doesn't make sense to me. How steels work is not really open for discussion, the article explains why different steels have same stiffness. I am really at a loss here. The information is available do with it what you like.In fact the article you posted explaining how different steels have the same stiffness across different hardnesses due to how the molecules bond to each other would support different steels having different stiffnesses as they have different structures.
Hahaha... That's a good point! And thanks for asking this clarification.Has anyone else done any tests? The fact you said with fairness concerns me that you are skewed against busse in some way. and thus all your arguments will be flavored that way. Maybe you should ask this of all manufacturers. Let me ask you , what brand or makers knives are you heavily invested in?
Cobalt Adding more to my above answer: I have far more knives than I need, because I've never found the perfect one. And every time I purchased a knife, I felt like "wow, it is awesome... but it is still missing someting... I still need to continue searching" (does that sound familiar to any of you?
). This happened for more than 25 years to me, all the way until I got the SR Free Rein Wakizashi last year. When I received that one, it was for the very first time in my life when I felt that I finally have the knife of my dreams (in all aspects). Argumentation: it chops similar to a machete of the same size (and nothing can outchop a thin bolo machete weight-to-performance), weights just a bit more, is just as durable as a spring steel machete from the lower range of the 50s HRC, but has the additional thickness to split effectively, the additional wear resistance to hold an edge closer to the premium steels I have in the smaller knives (like M390, SGPS, K390), has some fair corrosion resistance, offers the type of tip that is both strong and deep penetration capable, has a handle that can accomodate either one handed or two-handed use for additional prying leverage, has the necessary stiffness to be used as a weapon if the situation asks it (which a thin machete doesn't), weights light enough for a tool of its size to be carried in my backpack, is just short enough to be conceallable on the trail, but long enough to offer more leverage than any knife, has a perfectly shaped 3D all-around finger guard to allow power stabbing without concerns of hand slippage if the need comes, and ressembles the simplicity of a (nearly) straight prybar that is usable in many ways, with no joints, no screws, no moving parts, no complexities. The more complex a thing is, the more likely it is to fail in nasty situations.
And my ecuation is simple: is INFI better than SR-3V? If so, it means I'm not done; I need to wait until someone will make an INFI version of the Free Rein with a Res-C handle and buy it. But if the conclusion is that the only advantages INFI brings over SR-3V stand in the ease of sharpening and slightly (nearly unnoticeable) corrosion resistance, then I'm done; I already have the best knife by my personal criteria! I don't care about the ease of sharpening at all. I sharpen everything with a DMT aligner and I make anything shaving sharp in just a few seconds. It is small and light enough to carry with me everywhere and I know the predefined angle for every of my knives.
I hope this answer also clarifies the purpose for which I've created this thread.![]()
The article doesnt expound on different steels- only different hardnesses.This doesn't make sense to me. How steels work is not really open for discussion, the article explains why different steels have same stiffness. I am really at a loss here. The information is available do with it what you like.
