- Dec 6, 2011
I will be picking up my Esteem grinder around the Christmas Holiday time, and will be getting it directly from Brett. I won't have it set up until some time in February. I will order and have a heat treat oven by then as well. (in the process of building a new house and shop).
I want to get together a belt order and have been using the search function and reading as much as I can about it, plus referencing the three knife books that we have. I will be using the grinder for profiling and finishing and will probably start with some 440C. I will probably use micarta for the first few knives. Here is what I was thinking:
36+ 984F Cubitron II Ceramic (3M)
60YF 967F Cubitron Ceramic(3M)
120 RB406JF Aluminum Oxide (Hermes)
220 RB406JF Aluminum Oxide (Hermes)
400 RB406JF Aluminum Oxide (Hermes)
Coarse Scotchbrite
Fine Scotchbrite
I would like to end up with a nice satin finish. Will probably heat treat after the initial grinding with the 220? Any recommendations on what paper to order for hand sanding, in addition to advice regarding belts, would be very much appreciated.
Coarse Scotchbrite
Fine Scotchbrite
