- Aug 16, 2018
Is cpm 3v if heat treated right as tough as 5160
personally, I say no...but, depends on "tough" definition....
I think.nobody sells 3V springs for the simple reason that they will break.
3V is not made to take flexing, but more, to resist flexing. If of a length and cross section, hardness, and load to resist flexing, it is mighty tough stuff...but a leafspring or antennae aerial it is not.
I will trust it to not deform when spring steel would dent...but 3V will fail where spring steel would spring...folk seem to be getting by with 3V on shorter swords, but not longer swords...max toughness in notch tests is in the 58-59Rc range, but, you also end up with a softer more dentable blade.
3v has been used in long swords for YEARS. Properly done 3v makes a better sword in my opinion for a variety of reasons. Swords aside, toughness is only one attribute and 5160 falls well short of 3v in corrosion resistance, strength and edge retention.
5160 will likely bend further, 3v will resist bending to the point you likely can't break it short of intentionally destroying it which literally any knife can be intentionally destroyed.
https://www.bladeforums.com/threads/cpm-3v-ko-katana.1616591/
The super assassin? I fell in love with it I think 4 years ago.. the last price I saw one for sale was over 5k I think LOLI MUST HAVE THAT SWORD !!!!!!
Chipping really isn't the issue when you're asking about toughness and talking about abuse.
Or , of course , Cold Steel !To answer the question posed in the original post:
No, I don't think 3v will deform the same way 5160 will. The goal of your knife shouldn't be to deform, it should be to resist deformation which 3v excels at. I don't want a bent knife or broken knife, chose 3v as done by Nathan Carothers, Ben Tendick or Dan Keffeler for top of the line pinnacle of performance 3v. It won't be cheap, but it won't be prohibitively expensive like a Bugatti.
From this vid it looks like 3V will at least get you through some light work in the yard.
The steel yard ! ! !
What was that other alloy you mentioned ? Oh well doesn't matter.
