robme, can you explain why you disagree?
I like to hear
Data sheet is available online.
I wouldn't post it if I didn't know it was correct....
I don't do BS and smoke screens, I say what I can...... What I don't know I don't talk about.
http://www.crucible.com/PDFs/\DataSheets2010\dsS35VNrev12010.pdf
All the info is right there on the data sheet..... Everything, edge retention, toughness, impact testing..... It's all there.
If you don't believe that PM Chris Reeve and he will tell you I am sure since he had 1st hand involvement in the development of S35VN so he should know something about it.
Thank you for the link.
You wrote earlier, "The improvements were to make it easier to work with and finish, not to improve the performance." and also later, (S35VN) "Takes a better finish and is easier to grind than S30V and likely easier to HT."
And from the Data Sheet...
CPM S35VN is a martensitic stainless steel designed to offer
improved toughness over CPM S30V. It is also easier to machine
and polish than CPM S30V. Its chemistry has been rebalanced
so that it forms some niobium carbides along with vanadium and
chromium carbides. Substituting niobium carbides for some of the
vanadium carbides makes CPM S35VN about 15-20% tougher
than CPM S30V without any loss of wear resistance. CPM S35VN’s
improved toughness gives it better resistance to edge chipping.
Because both vanadium and niobium carbides are harder and more
effective than chromium carbides in providing wear resistance,
the CPM stainless blade steels offer improved edge retention
over conventional high chromium steels such as 440C and D2.
The CPM process produces very homogeneous, high quality
steel characterized by superior dimensional stability, grindability,
and toughness compared to steels produced by conventional
melting practices.
Machinability and Grindability :
In the annealed condition, CPM S35VN is much easier to
machine than CPM S90V and easier to machine than
CPM S30V. Similar grinding equipment and practices
used for high speed steels are recommended. “SG” type
alumina wheels or CBN wheels have generally given the
best performance with CPM steels.
My bottom line... where I was coming from is that, from the POV of the machinist - It's no more easy to work with, grind or finish - It would take the same effort and and about the same amount of time to work on. It's not easier to HT, it wouldn't take a better finish. I'll still assure you that 'time to make the blade' is relatively unaffected. Nothing much changes here as far as I see it...
What I do read from the Data Sheet, is that... this easier to machine aspect means that there would be less wear & tear on the toolroom equipment machining tools, like lathe knives or cutting tools, milling tools, grinding wheels etc.. So this equipment would have more uptime and less frequent maintenance, and this is a good thing!
CRK isn't saving any toolroom time using this steel, and I don't see how their overall production costs would be greatly affected either. But they are producing a superior blade, and that's what Chris reeve knives are all about. I hope you now understand what I had in mind when I read what you wrote. Also BTW... It seems that (contrary to what you said) the performance of S35VN (15-20% tougher without any loss of wear resistance, and better resistance to edge chipping), would be considerably improved over its predecessor. Cool!
Rob
