- Sep 15, 2008
I couldn't quote everyone here since I'm replying to multiple posts.
1) SAKs are built in layers, and the whole knife is held together with brass pins and rivets which can be removed (with great difficulty, unless you have a special tool). The rivets hold the WHOLE knife together, and when removed you get the aluminum layers and all the tools from the knife separated, including the blade. There is no "separate" pivot for the blade and if memory serves me correctly, there are three brass pins on 91 mm models that hold the whole thing together. The scales are pressed onto the rivet heads and pins and are held by friction. The pins are not "spun on" but pressed in VERY tightly, which is one reason why there is virtually no blade play.
2) Try to slide the bill between the blade and the liner, whatever it may be.
3) Handle material should have NOTHING to due with blade play. The mechanical unit we are looking at is the blade, pivot, and liners/bolster/frame. Handle material is pinned, epoxied, inlayed, glued or whatever to the frame or liner and is considered a separate mechanical unit.
4) Not all "tacticals" are screwed, almost all production pieces are, but some handmades are pinned. I have a Prinsloo that is pinned, and was actually hoping it WAS screwed, since it has...guess what...
BLADE PLAY!:grumpy:
5) Blade play can be found in any style of knife and is not the nature of the slippie beast or anything else. It simply has to do with the tolerances (or more appriately LACK of desired tolerance) of the blade/pivot unit.
You have made my point, it is an apple to oranges comparison. On a bolstered knife the pins cannot be pressed in VERY tightly, they are peened into a countersunk space. So saying Victorinox can make knifes without blade play so ___________ other company should be able to also is not valid. You could argue that a bolstered knife should not have any blade play if it is constructed correctly, but comparing them to SAKs is not valid.
