These people who think that you should buy a BK2 because the 9 is too big are funny. The 2 is a mere 5 ounces lighter, and actually feels heavier, which should tell you quite a bit considering it's so much shorter. Comes from having much thicker stock. Then, to suggest you pack in a saw as well (thereby adding even more weight?), I have to wonder how many of them have actually handled a 9. The 2 was my second Becker. When I got a 9, I was impressed by how light and nimble it was, and not just for having a big long blade (18.25 very well balanced ounces). You won't be dissatisfied with any Becker knife, but the 9 in particular is one of the best.
I have no idea what is meant by "you can put the most power in a cut into the first 2 inches?" That's just not true. The correct area to cut is in the sweet spot of the knife, which will generally be designed by a decent designer around a harmonic curve out from the handle, usually towards the far end of the blade on a chopper. You can (hopefully obviously) put the most power into a cut farther away on a forward balanced knife, since you can use the weight and momentum of the blade to aid your cut. If you can't figure out how to control your knife, you shouldn't be buying any knife anyways, or else you should, you know, practice until you can use your blade safely. It's not that hard, particularly not for someone who already owns a hatchet, which is even MORE forward balanced.
The BK-9 is never "too much knife".
