Haven't had time to get out since early spring to the local flea market but this morning I got out and I was glad I did.
Heres my two Plumbs that followed me home.
The double bit is a Plumb 4lb. I didn't have one with phantom bevels yet. What pattern is a double bit with phantom bevels?
Last but not least a big ole Plumb I weight it on my scale with the handle and it weighed in at 6lbs 8 ounces so maybe a 5lb single bit?
Is this a Connecticut? If so its my first and goes with my 5lb Plumb double bit that I got from the same old fella.
i would call that a dayton or a wide dayton. the bit is a bit long and not quite wide enough, and the poll is squared instead of tapered behind the eye.the eye is "normal" size also, not the common enlarged connecticut eye.
very nice axes, both of them.
the double bit looks to be a Western pattern with bevels, like the quintessential double bit, the Kelly Perfect Western pattern. the western pattern and michigan patterns are very similar, with the only mentionable difference being the heels and toes of the bits. the western pattern come to an abrupt point on both heel and toe, with little arc between the two.. the michigan has very rounded heels and toes, and noticeably more arc to the bit. the michigan is a much more "well rounded" ax, and performs in MANY types of wood fairly well. the much more "flat" bit of the western works a bit better in more specific species. both are great patterns, i personally prefer the western myself.
many western patterns were turned into "michigan" patterns, their owners tended to over file the heel and toe of their ax bits....
