- Apr 14, 2007
Hi,
Frankly, there isn't a lot that is truly new under the sun anymore. Just how many ways can you design a knife that somebody else hasn't already tried?
dalee
Bingo!
Hi,
dalee
A Spyderco that looks like a Benchmade that uses a Spyderco hole! I can imagine there'd be a bit of a resemblance.)
For example, have you noticed how the Spyderco D'Allara looks like the Benchmade Mini-Griptillian?
Not just the hole. I think this was a rare instance where Spyderco designed something that looks like a competitor's model, rather than the other way around. Notice the blade shape and the look and materials of he handle. You can't see it in the photos, but the D'Allara is about the only fat-handled Spydie I can think of. it's girth is similar to the Grip. Also the ball-bearing lock seems like an attempt to compete with the AXIS lock.
Exactly! It's a flat piece of metal that has to have certain shape, otherwise it is not a knife anymore, How may variations you can do on the pretty much flat surface with limited geometry anyway...Unfortunately, virtually every curve has been done by someone somewhere. I don't think it is a question of copy catting.
I've owned them both and in that photo they might look similar but in use they're quite different.
Pika was based on the Benchmade AscentII not the Delica.
God Bless
Wenger Standard Issue
Victorinox Soldier
Those Swiss Bastards!!!![]()
Or how about the new Boker Jetstream and the Chris Reeve Umnumzaan?
Wasn't the D'allara released before the round hole, hollow grind version of the grip? I don't know for sure but I'm pretty certain the D'allara was released when benchmade was using the flat saber grind and thumbstuds or an oval hole, then released the pictured version much later.
The locks are similar, and the blade shape...the rest isn't. Wire clip vs standard clip, D'allara has thinner grips with a palm swell and full length steel liners, different handle texturing etc. I've owned them both and in that photo they might look similar but in use they're quite different.
How about the SOG Bluto and the Kershaw Baby Boa?
I don't consider it a copy.
diff blade shape
diff handle shape
diff grooves
Do you mean no one should produce a folder with a titanium (in this case aluminum) handle any more?
