If you draw a horizontal line through 1.4116, you will see many other steels with the same toughness.420HC and 4116 have similar abrasion resistance, but 420HC is significantly tougher.
This is Larrin’s chart. 420HC and 4116 are the two left-most steels on the chart, but the difference in toughness is serious.
absolutely.If you draw a horizontal line through 1.4116, you will see many other steels with the same toughness.
Definitely chippy enough to get tossed into the drawer for communal use after mine got chipped. I absolutely love the handle ergonomics though. I just wish they made a version with a tougher blade steel.I have a Finn Hawk in 4116 that I find to be exceptionally "chippy." Basic de-barking and whittling left the edge with a number of small chips with the rest still being reasonably sharp, so they made it too brittle in the heat treat or it's just not tough enough for that grind. It was Cold Steel pre GSM, so you'd think that a knife good for "hours of hard use" would have done better, but it wasn't worth the money to send it back and it's not worth the time to fix such a brittle edge. It's hard to compare budget beaters with higher end knives, but I'm not sure how much better you can make 4116 versus just using a slightly better grade of steel--even AUS8 treated me better.
they're all like this. radiused on both sides to remove stress points where the guard fits. I have another in horn...From the pic I'd say the build quality is low, the guard isn't fit well. Maybe a rehandle and fix the guard.
They look good all around.they're all like this. radiused on both sides to remove stress points where the guard fits. I have another in horn...
they aren't perfect and I don't know the price points nowadays on them but when I got mine they were quite cheap for made in Spain.....
Odd thing is in Virgina Bowie knives are illegal. Go figure.old ladies didn’t like ugly men showing up to church with big knives tucked away in their belts.
Sorry about the whole steel thing…. But if you are going to get a Bowie. It should be at least 3 to 4 inches wide and 6 to 7 inches long.
There is a a lot mystic about the origins of the Bowie knife.
I always imagined just as you should be able to chop down a small tree with a Bowie. You should be able to slap someone in the face with one also.
I love these as very traditional looking, I've no problem with the steel used (1.4116 iirc) similiar to 420hc? As for a traditional larger blade it's absolutely fine ime.
Does anyone have any experience with a Joker Bowie, FnF, steel etc...?
4116 is a kitchen knife steel. I don't have a problem with it, but it gets generally looked down upon on BF.
If it works in the kitchen, why won't it work elsewhere?
Now that's a knoife!1.4116 (aka X50CrMoV15) is definitely a kitchen cutlery steel, prioritizing corrosion resistance and ease of sharpening over edge retention. Wusthof, Zwilling/Henckels, and Victorinox all use it. It's generally run a bit softer than it needs to be to survive amateur kitchen use. If it can make a decent 8-10" chef's knife, I don't see why it couldn't be used on a Bowie of a similar or shorter length (and probably double the stock thickness). But, for the $150-175 Joker sells the 1.4116 Bowies at, I don't think it's particularly good value. The Buck 120 is around $100 in 420HC (or $200ish if you want S35VN), and there are a bunch of TOPS knives that are similar in price to the Joker. The Down Under Knives Walkabout in 440C that C ChrisLee mentioned is only about $10 more than the Joker and looks nicely made.
