- Feb 8, 2017
Chin, That's a fine looking Lambs foot you have there. That ones on my short list.
Nice! Is that a strop in the background?
Thanks and yes Sir ! Works really well to and actually my favorite strop block . It comes loaded with green compound and last for ever ! It's a strop block from KNIVESPLUS and highly recommend it . I've had it for a few years and it's my go to strop always .
[/URL][/IMG]![]()
Well! Thanks. I've been using my Edge Pro up to 1200 then either the included stick / ceramic strop, or going with a 2000 tape on the edge Pro. The tape can be a pain, so maybe it's time for a different final finish? Maybe it's time for a strop block? [emoji41][emoji6]☺[emoji2]
Another outstanding composition that you can stare into for a good while. That could be an ad for Old Timers!:thumbup:
If you only use your knife for light use it's great to bring a edge back or even lightly polish the blade . It'll bring it back hair popping sharp as long as you don't have bad burrs on the edge . Sometimes I'll hit mine once a night if I've used it more then normal . If not a couple of days a week and let it be known it's somewhat addicting always being able to get that razor sharp edge and feeling and hearing your blade sliding across the strop . There easy to use just remember light pressure is all you need because you can round the edge trying to rush it and pushing hard the leather will slightly wrap around the edge and that's all it takes to round your edge . A convex edge you just slightly roll the knife until you hear the slight contact of the edge and you can actually feel it . When you get to the end of the block just lift the blade straight up and don't roll it .
It's easy to roll it and not realize it but you'll know what I mean after some practice trial and error .
I'll even use the block sometimes after using my edge pro even after taking it to 3000 just because I like it .
You may know all the tricks but just in case you haven't used a strop block thought I'd throw some tips out there so you can get the most out of it [emoji106]
Thanks and No Problem my friend 👍Thank you sir. For several years, I have been using the EP and not really hand stropping. Good tips.
