Instead of weighing yourself another way to see if you're in the ballpark of the right weight, your waist should be half your height. For example I'm 5' 10" which is 70", divided by 2 equals 35". Half your height will put you on the high end of what your waist should be.
Fascinating, I'd not heard of that, before. Of course, one's body type and bone structure will dictate the nuances of ideal waist circumference (32" vs 34", for example), but your guide sounds like a good ballpark range, Phil.
I've been following this thread since its inception, and you guys are doing well. I've been through a weight loss, as well, and it IS hard. Persistance (and perspiration!) are key. I went from 225 to 195, which is close to my ideal size. One thing to remember, that I've found from experience, is - don't discount intense weight training as an
excellent fat loss tool. Cardio exercise is good, but recent research has been finding that weight lifting is far more beneficial for fat loss and cardiovascular health than previously thought.
Because I'm stoked about it, I'm gonna tell y'all about the best lifting routine I've experienced. You ready?
It's called Escalating Training Density, EDT for short. Charles Staley is the formal originator of the concepts; you can google him to learn more.
The basic premise of the theory is that muscle groups are made to contract in short bursts and then rest in short bursts. The methodology for the lifting is to take 2, 15 minute blocks and lift during them. The exercises performed in each block consist of 2 antagonist muclse groups, such as the chest and the back, the biceps and triceps, or the quads and hamstrings. For 15 minutes, the lifter supersets the 2 exercises. The weight used for each lift is whatever the person's 10-rep-max is. For example, if I can bench press 100 pounds 10 times, but not 11, then I'd use 100lbs for the bench. I'd then pick a rowing motion exercise and find my 10-rep-max at it. The kicker is this - I only do about 5 reps per exercise per set. I would bench 5 reps then immediately go and row 5 reps. I would rest as little as possible then do another bench/row set. The goal is to attain 50 reps per exercise in 15 minutes. Rest time between supersets necessarily gets longer as the time block goes on. Ultimately, the lifter is self-paced, resting when necessary and lifting intensely when able.
It's a very effective lifting strategy for a whole bunch of reasons -
- it's very time-efficient. 2, 15 minute blocks will cook anyone's goose. Doing this 2 or 3 times/week, when using appropriate exercises, will stimulate the whole body in terms of volume and intensity.
- the muscles are worked the appropriate amount. The lifter can only lift so much before being forced to break for a bit.
- the muscles are able to work more than in a normal lifting routine. Yep, that's because lifting with an antagonist muscle group allows the first muscles to stretch and rest more deeply than if they were just "hanging around"
- this is the most intense cardio work I've ever done. I sweat gallons and buckets when I do this
- I, personally, was able to get stronger and gain some muscle mass & definition while dropping fat. Even people at the gym were commenting on how I was looking leaner and more muscular.
So, all that to say, there are some very effective ways of lifting weights that are not boring :thumbup:
